JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications TTE SC pipework size???
Pages (4): 1 2 3 4 Next
rob
14-11-2016, 03:36 AM
Hi all,
need some help from someone that owns a tte SC. My car is in switzerland but im in UK for now otherwise would check it myself.
i want to confirm that the main pipework is 60mm and the bypass tube etc is 50mm?
i was looking at the posts from Dimitris and he has used reducers to fit his new IC which has 63mm ends but some info i found says the pipwork is 60mm, so i dont see the need for 63-60mm reducer.
I then found some posts from the turbo diesel infamous london tuning company that says the pipe work is 50mm...
anyone be kind enough to measure and confirm the actual pipe sizes??? :thumbup:
rob
14-11-2016, 03:36 AM #1
Hi all,
14-11-2016, 03:46 AM
Can one of you guys with the supercharger be so kind and measure the pipe wrk for Rob
14-11-2016, 03:46 AM #2
rob
14-11-2016, 03:49 AM
Gord I did do a post on this on loc, with all the sizes mate, but im sure someone will look for you :biggrin:
yep i saw that one mate and it says 60mm but as i say i am a bit confused as the IC Dimitris has he needed reducers and that meant to be 63mm inlets.
rob
14-11-2016, 03:49 AM #3
14-11-2016, 05:11 AM
This is Gords post fro the dark side............
1 x 70mm wide by 80mm long = airbox to charger
1 x 60mm wide by 160mm long = lefthand side joint pipe going to intake
5 x 60mm wide by 100mm long = from charger to/from intercooler
1 x 50mm wide by 50mm long = bypass valve
1 x 50mm wide by 90mm long = bypass T pipe joint
14-11-2016, 05:11 AM #4
14-11-2016, 05:14 AM
Only need reducers if you bought a new intercooler like Dimitris
14-11-2016, 05:14 AM #5
rob
14-11-2016, 06:50 AM
try find me a 63-60mm reducer... you dont get them, unless the IC ends are not actually 63mm or the pipework is 50mm etc.
rob
14-11-2016, 06:50 AM #6
14-11-2016, 06:55 AM
Well the silicon hoses that go from your intercooler to the pipe work are just straight hoses that fit the 60mm pipework
14-11-2016, 06:55 AM #7
14-11-2016, 06:56 AM
rob try find me a 63-60mm reducer... you dont get them, unless the IC ends are not actually 63mm or the pipework is 50mm etc.
[URL="http://www.roosemotorsport.co.uk/product_info.php?products_id=597"]
Linky[/URL]
14-11-2016, 06:56 AM #8
Linky[/URL]
rob
14-11-2016, 08:02 AM
ok so is it confirmed the pipes are 60mm?
ta 4 the link to the reducer but no way in hell im paying 15 fo it!
rob
14-11-2016, 08:02 AM #9
14-11-2016, 08:04 AM
So have you bought a new intercooler and want to fit it onto the TTE piping ?
14-11-2016, 08:04 AM #10
Views 353
16-09-2020, 08:38 AM
Last Post by philip_98
Views 742
18-09-2019, 10:35 AM
Views 511
17-12-2018, 10:18 AM
Last Post by S
