Alarm Problem
Alarm Problem
Quote:"When armed, the system will automatically enter pre-arm mode. If an alarm trigger is received during this time, the alarm does not activate the siren and blinker command but only gives and acoustic warning signal by the buzzer with a continues sound until the cause is removed or the system moves into full arm mode. In the second case, the input triggered will be excluded during the Arm mode."
Note: Ultrasonic sensor and self powered siren (tamper alarm) are not signalled during pre-arm time.
At the end of the pre-arm time (10 sec.) the system will enter in full arm mode"
Not sure if anyone can help me or if I should just bite the bullet and head down to a dealer.
Basically, I cant set my alarm off. Its the standard Nissan one.
I was reading through the stuff that came with the car (finally) and in the Nissan anti-theft system book it mentions if you lock the car and there is something that should set the alarm, a buzzer should sound while the car is in pre-arm state (lasts 10 seconds after locking).
To quote the book itself:
try sitting in the car and doing it,
alternatively, open the door and then hold the door switch in (the one that turns the interior light on/off, lock the car and after the set time release the door switch, that should set it off.
The buzzing noise comes from drivers side rear quarter I think as mine does it when ever I set the alarm lol admitidly it's an aftermarket alarm....
Depending on how confident you are I know of a walkthrough to install an aftermarket alarm for the 350z....
Drivers side rear quarter is kinda were the alarm siren/black box is.
Something like the alarm I wouldn't to mess with myself.
I would rather get the standard alarm sorted if I can but if its going to cost a bomb ill probably get an aftermarket one fitted.
Sparkystav try sitting in the car and doing it,
And the alarm didn't go off?
That's worrying!
Interestingly though I managed to make it beep by trying to lock the car with the key in the ignition.
That sounded like it was coming from the siren in the boot so I think it's powered...
Sent from my GT-I9100 using Tapatalk 2
