JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Lowering my is
Lowering my is
Lowering my is
Coopdog
22-11-2020, 04:53 PM
Right I've been told a couple of different things,
With the lowering springs are they 40mm drop on a standard IS or is it 40mm from the sport with the 15mm?
Also what's the max I can go on standard springs? 40mm?
Any pics of 40mm drop?
Just using springs until I can't get coil overs
Coopdog
22-11-2020, 04:53 PM #1
Chris0121
22-11-2020, 05:02 PM
Tenzo r do a 50mm drop and looks real nice and its a level drop some cheap springs the back can sit higher than the front jay jay used to run tenzo's have a look for his build thread mate
Chris0121
22-11-2020, 05:02 PM #2
Coopdog
22-11-2020, 05:10 PM
Where would I look? New here,
Are 50 springs ok to use?
Coopdog
22-11-2020, 05:10 PM #3
22-11-2020, 05:22 PM
save the spring money for a bit longer until you can afford coilovers.
22-11-2020, 05:22 PM #4
Coopdog
22-11-2020, 05:25 PM
el_bandido save the spring money for a bit longer until you can afford coilovers.
Hmmmmm I dunno :/ I can't justify paying £100 to lower my car not £500 on the coil overs I've seen for sale
Coopdog
22-11-2020, 05:25 PM #5
22-11-2020, 05:48 PM
Trust me when I say save ur money for coilovers,
I'm on springs and can't wait to upgrade its a pointless task.
22-11-2020, 05:48 PM #6
Coopdog
22-11-2020, 06:12 PM
Lexuspat Trust me when I say save ur money for coilovers,
whats the matter with them then?
Coopdog
22-11-2020, 06:12 PM #7
Rolex
22-11-2020, 06:33 PM
I had PI Springs on my IS200 and found them to be really good. The only thing I will say after you have lowered it is to get your Geometry adjusted otherwise you will start to eat through tyres.
Rolex
22-11-2020, 06:33 PM #8
22-11-2020, 06:35 PM
If all you want is to make the car look better then there's no problem just using springs which cost substantially less than coilovers.
And to answer your original question, the quoted figures are drop for a stock car. So if you have a Sport model then take 15mm off the drop. i.e. if you put 40mm springs on a Sport then it will only drop it 25mm.
However if you are still planning on getting coilovers in the future aswell, I would just wait and put the money for springs in a piggy bank for the coilies Smile
Edited 03-01-2013, 10:21 PM by sprinter2012.
22-11-2020, 06:35 PM #9
22-11-2020, 06:48 PM
That's pretty much my point made above, if ur plan is to get coilovers then just save up
22-11-2020, 06:48 PM #10
Views 383
14-03-2023, 03:34 PM
Last Post by VVT-Einstein
Views 593
11-07-2019, 04:29 PM
Views 887
07-01-2019, 08:33 AM
Last Post by deckie77
Views 1,268
18-11-2017, 10:24 AM
Last Post by alamkhan3980
