JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Help sourcing injectors. :)
ozzie b
09-01-2020, 04:37 AM
Can anybody help me with sourcing these please, noticing a lot of cheap clones and knock offs, just want to be sure of the quality i'm gonna be getting so if anyone has any feedback on a reliable source lemme know Smile
Thanks folks.
ozzie b
09-01-2020, 04:37 AM #1
Thanks folks.
ozzie b
helps if i put what im looking for :p
195500-4450 - DENSO450 cc Toyota Lotus 1ZZ 2ZZ injectors x 6.
ozzie b
09-01-2020, 04:37 AM #2
09-01-2020, 04:54 AM
ozzie b helps if i put what im looking for :p
Is that the right part number? Can't find it on toyodiy
09-01-2020, 04:54 AM #3
ozzie b
09-01-2020, 05:06 AM
yeah pretty sure, not sure its the correct cc though as it depends on the pressure doesnt it?
ozzie b
09-01-2020, 05:06 AM #4
09-01-2020, 06:35 AM
1ZZ injectors are 23209-22040 (certainly on EUDM and JDM MR-S 99-05)
2ZZ injectors are 23209-22060 (from a JDM Celica) or 23209-22030 (from an EUDM Celica)
195500-4450 isn't a Toyota part number, the - is in the wrong place (should be 5 digits either side). 19550-04450 isn't a valid part number.
09-01-2020, 06:35 AM #5
ozzie b
09-01-2020, 06:54 AM
Thanks guys, certainly cleared that up for me, I'm such a ****** amateur Smile don't suppose u know of a good place to get hold of these or shall I keep my eyes peeled on fleabay?
ozzie b
09-01-2020, 06:54 AM #6
09-01-2020, 06:59 AM
Ah. 195500-4450 is the Denso part number for some MX5 and RX8 injectors (yellow) @ 450cc/min. Is that what you're after?
[Image: d1955004450.jpg]
Edited 19-02-2013, 04:34 PM by toxo.
09-01-2020, 06:59 AM #7
ozzie b
09-01-2020, 07:02 AM
Yeah they were the ones I was after, should of said rx8 yellow really shouldn't I, have to sneak on quick at work is the the problem. Which ones are best and are they all pretty much plug an play with a re map??
ozzie b
09-01-2020, 07:02 AM #8
09-01-2020, 08:03 AM
Unfortuanly mate you'll need new plugs with almost all injectors so they needs soldering on.
09-01-2020, 08:03 AM #9
ozzie b
09-01-2020, 09:28 AM
is it simple as just soldering the injector plugs or is there more to it than that? I thought I read somewhere that the 1/2zz ones were a straight swap Confused thought that was too good to be true. What do u recommend going with , looking to get my bits together for future upgrades with remap etc but want to get the injectors pretty soon to get the ball rollin.
ozzie b
09-01-2020, 09:28 AM #10
Views 570
11-04-2019, 03:04 AM
Last Post by LEX11S
