JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Sump gasket/seal
Sump gasket/seal
Sump gasket/seal
James S
15-01-2020, 03:48 AM
How difficult is it to change the gasket/seal around the top of the sump?
Also I have a a leak on the crank seal and rocker cover! I know I might as well change the timing belt while doing the crank seal, but is the rocker cover difficult?
James S
15-01-2020, 03:48 AM #1
15-01-2020, 03:56 AM
I hate changing sump seal, scraping it all off takes forever
15-01-2020, 03:56 AM #2
James S
15-01-2020, 06:52 AM
Is it hard to get too? Does the engine need dropping out because there is a big cross beam in the way! Lol!
James S
15-01-2020, 06:52 AM #3
15-01-2020, 07:34 AM
Yep, or the cross beam removing, but the steering rack is attached to the beam so that needs removing as well
15-01-2020, 07:34 AM #4
James S
16-01-2020, 03:36 AM
Sounds like too big a job tbh. The bills to fix it are greater then the car is worth.
James S
16-01-2020, 03:36 AM #5
16-01-2020, 08:32 AM
On the plus side, the rocker cover's easy!
16-01-2020, 08:32 AM #6
James S
16-01-2020, 12:51 PM
Lol! True! :-)
James S
16-01-2020, 12:51 PM #7
Lol! True! :-)
Views 681
03-05-2019, 06:00 AM
Views 292
19-05-2018, 04:02 AM
Last Post by jimxms
Views 335
09-02-2018, 03:38 PM
Last Post by Phil01
Views 317
08-03-2017, 10:28 AM
