JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Head Gasket Help! - Pics needed!
19-04-2019, 11:45 PM
Right as my parts "overnight from Japan" have been delayed till the 12th im desperately trying to figure out how to get the car back on the road.
Water gaskets i can make, manifold gaskets im ok for as well.
Valve stems are ok as their the same as the 3SGTE, Cam shaft seals are the same as the Yeris oddly so thats ok.
the only part i need is a headgasket.
Now in my head it cant be any different to the 1GFE IS200 one as its the same block in principle, but has anybody got a picture of, or can take one of the 1gfe headgasket so i can compare.
need it asap
thanks.
19-04-2019, 11:45 PM #1
need it asap
thanks.
20-04-2019, 01:36 AM
different part numbers on toyo-diy i'm afraid mate
20-04-2019, 01:36 AM #2
20-04-2019, 01:45 AM
yeah ive looked at that, but i cant see their actually being a difference between them.
ive googled it but you dont know if their a generic pic or not
20-04-2019, 01:45 AM #3
20-04-2019, 01:50 AM
i may be wrong here but just a guess and going by the 2JZ HG's which i know aren't the same for GE and GTE as the GTE is a lot thicker to lower compression.
Possible that this is the same for the FE and GTE maybe?
20-04-2019, 01:50 AM #4
20-04-2019, 04:09 AM
The HG isn't thicker to lower compression - thicker head gaskets are a pikey way of lowering compression aftermarket. It's thicker because it's metal not paper due to much higher combustion compression due to boost.
I'm not sure your 'same block' approach works Stav, in theory the 1UZ is always the 'same block' but the HG is quite different between revisions. Different oilways for VVTi actuation and sometimes different coolant paths.
You might just have to wait it out Sad
Edited 31-05-2012, 01:45 PM by toxo.
20-04-2019, 04:09 AM #5
20-04-2019, 06:42 AM
Ay I may have to. Got one on order but be good if I can get sorted quicker.
20-04-2019, 06:42 AM #6
20-04-2019, 06:43 AM
Wonder what Dave almost finished uses?
20-04-2019, 06:43 AM #7
20-04-2019, 07:50 AM
My Toyota guy is saying ETA of the 9th if he orders the HG today. That plus time to get it to you probably works out the same!
20-04-2019, 07:50 AM #8
20-04-2019, 08:22 AM
Nevermind. Thanks for asking.
20-04-2019, 08:22 AM #9
LEX11S
03-05-2019, 05:16 AM
daves car stav uses the std headgasket as far as i know thats what ive used
LEX11S
03-05-2019, 05:16 AM #10
Views 243
16-09-2020, 08:21 AM
Views 660
02-04-2020, 12:06 PM
Last Post by is300_dino
Views 196
27-03-2020, 05:33 AM
Last Post by ozzie b
Views 218
16-01-2020, 12:51 PM
Last Post by James S
Views 210
03-12-2019, 02:58 AM
Views 229
01-12-2019, 05:21 AM
Views 322
17-11-2019, 09:21 AM
Last Post by jomo
Replies 35
Views 1,302
02-11-2019, 12:11 PM
Views 287
28-06-2019, 12:32 AM
