JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Alternator help needed
Gr1NcH
02-12-2020, 07:13 AM
This is probably a basic question but before I tighten my alternator belt on the is200. Is there a tension locking nut and where would I find it. I can see the adjustment bolt.
Thank you for your help guys.
Gr1NcH
02-12-2020, 07:13 AM #1
02-12-2020, 07:37 AM
Iirc theres 2 tensioners i cant remember which is the 1gfe.
there's a tensioning pulley to the left of the alternator.
Should be a threaded bar beside it. Turn that and the pulley will move up and down tightening or loosening the belt.
Or it may be on the alternator. Once again a threaded bar but you have to loosen but not remove a small bolt to let it slide first. This should move the alternator up and down on a pivot.
02-12-2020, 07:37 AM #2
Gr1NcH
02-12-2020, 08:08 AM
Cheers sparky
Gr1NcH
02-12-2020, 08:08 AM #3
Cheers sparky
02-12-2020, 08:16 AM
Loosen the bottom bolt too mate (it has a nut on the rear), or you have a chance of breaking the cast bracket that holds it in place if you don't!
02-12-2020, 08:16 AM #4
Gr1NcH
02-12-2020, 08:38 AM
I found the locking nut. It's directly under the threaded bar on the alt Thanks again sparky.
Gr1NcH
02-12-2020, 08:38 AM #5
Gr1NcH
02-12-2020, 08:40 AM
Makes sense bandit. The alternator moved freely but I see we're your coming from. The locking nut was hard to see at first. All sorted now. Thanks mate. G
Gr1NcH
02-12-2020, 08:40 AM #6
02-12-2020, 08:47 AM
Glad it's fixed mate.
02-12-2020, 08:47 AM #7
Views 1,512
02-04-2021, 05:54 PM
Last Post by is300_dino
Views 518
30-11-2020, 11:10 AM
Views 433
06-10-2020, 11:00 AM
Views 1,147
02-05-2020, 11:49 AM
Views 857
21-04-2020, 09:12 AM
Last Post by Tomcat
Views 1,457
09-01-2020, 05:55 PM
Last Post by S
Views 2,045
14-12-2019, 02:47 PM
