JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Advice needed from people with TRD skirts...
21-01-2020, 11:58 AM
I'm just doing some final prep (sanding etc.) to the skrits before they go to the sprayers with the bumper. And I thought I'd just hold them up against the car to check the fit, but annoyingly they don't...
The TRD Skirts have 3 or 4 lugs/tabs along the bottom which are supposed to bolt up under the sills of the car. I watched them being removed from the Altezza they used to be on, and there were some plastic inserts which popped up into holes in the sills, which you could then screw into.
Now I have discovered after my test fit, that the underside of the sills on my car appear to have been weatherproofed or stone chip proofed or something. Because the whole length of the sill is full of what appears to be some sort of rubbery silicone substance. Meaning the bottom of the skirts tries to push away from the bottom of the sill as it can't go up into the recess.
Is this weatherproofing something that all UK models had, or did the previous owner get it done do you think?
Looks like the only solution is going to be to cut off all the tabs so the skirts can sit flush with the car? As none of you guys seems to use the lugs anyway, it's only the bolts at each end and some double sided tape which seem to get used.
21-01-2020, 11:58 AM #1
21-01-2020, 01:02 PM
Certainly mine fitted straight on without any messing about. Sounds like something that was done just to yours matey...
21-01-2020, 01:02 PM #2
21-01-2020, 03:01 PM
Mine has some weatherproofing on as well.
21-01-2020, 03:01 PM #3
21-01-2020, 03:25 PM
Sparkystav Mine has some weatherproofing on as well.
Did it affect how the skirts fit? Or do your ones not have fixings underneath?
Edited 03-03-2012, 07:12 PM by sprinter2012.
21-01-2020, 03:25 PM #4
21-01-2020, 03:30 PM
No fixings underneath mate, just each end and bonded along the side.
21-01-2020, 03:30 PM #5
21-01-2020, 03:35 PM
Sparkystav No fixings underneath mate, just each end and bonded along the side.
Good stuff, no one ever uses the fixings underneath anyway so I'll just chop them off and fit them like yours are. I'm really tempted to carbon skin the skirts now, but I just don't have the time.
21-01-2020, 03:35 PM #6
S
21-01-2020, 04:06 PM
Mine are only bolted at each end and double sided sticky foam along the top edge, no fixings underneath.
S
21-01-2020, 04:06 PM #7
P.Lindblom
21-01-2020, 06:16 PM
Did you get the eight plastic bits with the side skirts mate?
If so, just hold them in place to see where they are supposed to be attached. Then with a screwdriver, poke the layer of rust proofing around the areas where the screws should be. There are four holes under each sill and when you poke the proofing on top of them it will bulge inwards. If you want to use these underside fittings you just cut away som of the proofing on and around the holes. The plastic fittings just clips into place, then you can screw your side skirts to them.
If you didn't get the plastic bits, just do what the other guys suggested Smile
P.Lindblom
21-01-2020, 06:16 PM #8
Views 724
29-08-2021, 12:58 PM
Views 969
02-04-2021, 05:54 PM
Last Post by is300_dino
Views 357
02-12-2020, 08:47 AM
Views 335
30-11-2020, 11:10 AM
Views 1,022
22-05-2020, 11:05 AM
Last Post by sprinter2012
Views 836
02-05-2020, 11:49 AM
Views 589
21-04-2020, 09:12 AM
Last Post by Tomcat
Views 846
09-01-2020, 05:55 PM
Last Post by S
