JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! how to do ecu reset on is200
gazzi123
17-01-2020, 05:12 PM
Hi all,
Currently ive always since buying my is200, had horrendous MPG (i know they love the juice, but having 15-18mg around town) is becoming a pain in the ass.
i always keep on top of servicing - had recent long life plugs/synthetic oil/and all filters changed/ all belts changed (as didnt like a squeeling when it was damp)/ new ball joints/ all new brakes etc etc everything is always kept on top of.
But ive heard doing an ECU reset helps resolve the matter of poor mpg, do i have to take it to a tuning place or is there any step by step guides for me to do it myself?
Cheers Smile
gazzi123
17-01-2020, 05:12 PM #1
Hi all,
Cheers Smile
gazzi123
17-01-2020, 05:21 PM
.....Just think on the actualt Voltage reading (i thinks thats one of the dials on main speedo clock) the highest it reaches is 9.5 ......Is this too low? and affecting my mpg/power?
gazzi123
17-01-2020, 05:21 PM #2
17-01-2020, 09:21 PM
Battery voltage should be 13 to 14volts get a volt reader and check the terminals at the battery and alternator. To reset the ecu just disconect the battery for 5 to 10 minutes
17-01-2020, 09:21 PM #3
18-01-2020, 02:12 AM
It also depends how you drive once you've reset the ECU.
18-01-2020, 02:12 AM #4
18-01-2020, 05:03 AM
Check the tyre pressures asap!
I was getting low 20s MPG, checked the tyres and found they were all about 30psi, so I pumped them back up to 45psi and bob's your uncle, close to 30mpg now Smile
18-01-2020, 05:03 AM #5
18-01-2020, 06:29 AM
45psi! I bet you do get really good MPG with overinflated tyres, you've got very little contact with the road so less friction :lol:
Edited 28-02-2013, 04:03 PM by toxo.
18-01-2020, 06:29 AM #6
18-01-2020, 06:30 AM
In fact, isn't that near maximum pressure for the tyres?
18-01-2020, 06:30 AM #7
18-01-2020, 06:38 AM
toxo 45psi! I bet you do get really good MPG with overinflated tyres, you've got very little contact with the road so less friction :lol:
They are 18s if that makes a difference? I thought the lower profile means you need higher pressure?
Sent from my LT26i using Xparent Skyblue Tapatalk 2
18-01-2020, 06:38 AM #8
18-01-2020, 06:56 AM
i dont normally go higher that 35 psi in my tyres, sure tony at wim recocomended around 34-36psi
18-01-2020, 06:56 AM #9
18-01-2020, 07:02 AM
sprinter2012 They are 18s if that makes a difference? I thought the lower profile means you need higher pressure?
Have a look on the sidewall of the tyre and see what the maximum rated pressure is. If you fill them cold you can add 3-4psi for when the air in the tyre is hot (maybe less for low profile tyres as they have a lot less air in).
18-01-2020, 07:02 AM #10
Views 1,709
21-03-2024, 04:36 PM
Views 886
19-02-2023, 01:37 PM
Views 2,226
15-02-2023, 12:16 AM
Last Post by cjoseph
Views 1,039
07-05-2022, 10:47 AM
Last Post by piman2k
Views 2,635
16-05-2021, 11:52 PM
Last Post by AARONMCCONNELL1
Views 1,146
20-03-2021, 09:49 AM
Last Post by Millo73
Views 858
16-03-2021, 11:12 PM
Views 1,281
04-12-2020, 12:16 AM
Views 4,514
15-04-2020, 10:52 AM
