JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Emanage ultimate help?
argyle dan
24-02-2020, 10:31 AM
I need some help, tried to install the ultimate today and now my car isn't running right, I've checked the wiring all seems ok,it's not telling me that its wired up wrong, checked the jumper settings all seems ok, the only thing I've done is install 550cc injectors at the same time and a bigger pulley,
In hindsight should of done the ultimate first then the other bits.
I've wired the ignition wires in firing order but it smelling of fuel a bit and just sounding rough.
Anyone got any ideas, cheers
argyle dan
24-02-2020, 10:31 AM #1
24-02-2020, 10:34 AM
have you got the right base map installed?
24-02-2020, 10:34 AM #2
24-02-2020, 10:43 AM
Its because its over fuelling from the injectors! Have you put the old and new sizes in?
24-02-2020, 10:43 AM #3
argyle dan
24-02-2020, 10:55 AM
Yeah put in 210 for old ones, 550 for new ones, haven't got a base map, thought by setting the parameters it should be good enough to get us to the engine tuners.
argyle dan
24-02-2020, 10:55 AM #4
24-02-2020, 11:32 AM
I assume no ecu codes?
24-02-2020, 11:32 AM #5
argyle dan
25-02-2020, 02:41 AM
Eml is on but it won't let me connect , it's just saying not recognised, just rechecked jumpers and wiring all as it should be. Must be something on the parameter set up.
argyle dan
25-02-2020, 02:41 AM #6
25-02-2020, 03:03 PM
Need to get the codes first IMHO.
25-02-2020, 03:03 PM #7
argyle dan
26-02-2020, 01:52 AM
Read the codes nothing important,air intake temp. The car is running just about, I wired the ignition wires in firing order, do I have to do the same for the injectors. Sounds like I've got a misfire, no more eml codes have appeared (yet).
argyle dan
26-02-2020, 01:52 AM #8
argyle dan
26-02-2020, 02:27 AM
This is my wiring diagram for the Ecu connections
.jpg
argyle dan
26-02-2020, 02:27 AM #9
.jpg
26-02-2020, 03:02 AM
Seems right to me.
Two things- have you soldered it rather than crimps?
Also when programming the ecu use crank position rather than tacho signal.
What position are the jumpers?
26-02-2020, 03:02 AM #10
Seems right to me.
Views 306
03-10-2019, 11:45 AM
Last Post by JayJay1374
Replies 33
Views 1,786
26-05-2019, 11:22 AM
Last Post by S
Views 558
10-01-2018, 11:40 AM
Views 1,266
01-01-2017, 06:54 AM
