JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Coilover oppinions and a couple of suspension questions.
ozzie b
10-05-2020, 04:30 AM
So I am saving for some coilovers and have a couple of questions.
What is the standard spring rate of the is200? Either the sport/SE doesn't matter just would like a rough figure to gauge my set up from standard.
I am looking for camber adjustment also, camber plates on the front mounts but are is's adjustable on the lower suspension arms, if so is this do-able with the oem arms or do you need a camber kit? Same with rear>?
Cheers Folks.
ozzie b
10-05-2020, 04:30 AM #1
Cheers Folks.
10-05-2020, 01:38 PM
Ozzie if you look in the club sponsor section we have an arrangement with MeisterR that will save you money on coilovers. They're also pretty good with any advice and/or questions you have
10-05-2020, 01:38 PM #2
ozzie b
10-05-2020, 08:37 PM
Cheers Dave, I sent messaged about the Meister's already, maybe be tempted but looking for something a little different Smile
ozzie b
10-05-2020, 08:37 PM #3
ozzie b
10-05-2020, 08:42 PM
ozzie b
10-05-2020, 08:42 PM #4
reco2k
10-05-2020, 08:50 PM
I had hsd's on my old is very good coilovers lots of height and damping adjustment. Camber is an issue on the is though. With standard arms i could only get it back to -2 degrees from -3 thats about all the adjustment they had after that you need adjustable arms which are very very expensive so depends how low you want to go and want set up you want.
I have just fitted meister r to my rx8 and they are amazing bits of kit lovely comfort but solid in the corners and handles like a dream
Ross
reco2k
10-05-2020, 08:50 PM #5
Ross
ozzie b
10-05-2020, 10:00 PM
I'm not worried about too much camber, was only worried about too little :p -4 I could live with, so long as there is some adjustment on the arms it should be fine to tweak clearance issues and get the stance/performance I'm looking for.
ozzie b
10-05-2020, 10:00 PM #6
ozzie b
30-05-2020, 04:59 AM
So just to add, after a tiny bit of research I believe the is300 standard rate to be very close to the region of ; 5kg/mm (Fr) 5kg/mm ® Don't know how accurate these figures are as no-one seems to have a definite answer but I cant Imagine that they wouldnt be much stiffer than that.
Hope this is of help to folks in the future Smile
ozzie b
30-05-2020, 04:59 AM #7
03-06-2020, 01:37 PM
The MeisterRs come very highly recommended. Camber can be hard (expensive) to control though. If you go low enough you will get a 2-3 degrees naturally on the rear, I think. Ormi would know, check out his project thread.
Edited 15-07-2013, 11:11 PM by Stoney.
03-06-2020, 01:37 PM #8
Views 296
03-11-2020, 07:28 AM
Last Post by argyle dan
Views 505
04-07-2020, 02:03 PM
Last Post by mattlaw
Views 507
19-07-2019, 10:03 AM
Views 482
07-04-2019, 09:04 AM
Replies 31
Views 1,859
03-11-2018, 03:23 AM
Views 558
11-07-2018, 10:12 PM
Views 1,098
02-02-2018, 06:37 AM
Last Post by ekme
Views 775
29-06-2017, 11:55 AM
Last Post by James S
Replies 22
Views 1,444
21-05-2017, 10:46 AM
Last Post by ormi
Views 618
17-01-2017, 12:44 AM
