JapCarForum Cars, Cars, Cars! Wheels & Tyres How to measure wheel offset
04-06-2020, 11:51 AM
So for some reason you need to know the offset of your wheels???? Well its easy lol:
The offset should be marked on the wheel.
However you can measure it yourself with the wheel off the car.
Lay the wheel & tyre on the ground (outside up) and measure the distance from the ground to the hub mounting face using a tape rule (DIM A).
Turn the wheel over (outside down) and measure the distance from the ground to the hub mounting face again (DIM B).
Subtract DIM B from DIM A and divide the answer by 2 to get the offset.
EG: DIM A = 167.5mm; DIM B = 97.5mm; DIM A - DIM B = 70mm; offset = 35mm
Simples.
04-06-2020, 11:51 AM #1
Simples.
04-06-2020, 11:59 AM
Good post mate!
04-06-2020, 11:59 AM #2
Good post mate!
04-06-2020, 12:09 PM
Just something I came across - may help someone which is why we are all here lol.
04-06-2020, 12:09 PM #3
04-06-2020, 01:15 PM
I'm not
04-06-2020, 01:15 PM #4
I'm not
04-06-2020, 03:36 PM
purplewitch I'm not
You're not here?
04-06-2020, 03:36 PM #5
purplewitch I'm not
You're not here?
04-06-2020, 11:08 PM
where? no i'm not there
04-06-2020, 11:08 PM #6
Views 402
01-03-2023, 07:03 AM
Views 631
15-03-2021, 05:14 AM
Last Post by Morango
Views 643
17-05-2020, 12:17 PM
Last Post by Colin G
Views 811
24-12-2019, 09:51 AM
Views 1,296
25-06-2019, 07:38 AM
Last Post by Mr Reman
Views 1,059
06-01-2019, 03:49 PM
Views 615
15-09-2018, 03:34 PM
Last Post by sprinter2012
Views 871
10-09-2018, 10:37 AM
Last Post by mpls24
