JapCarForum Trade Area Wanted Smaller pulley
Smaller pulley
Smaller pulley
reganlives
06-08-2020, 05:19 AM
I got hold of a supercharger kit a couple of months ago and fitted all of it apart from the pulley and fcd. The kit was a stage 2 with larger injectors and an emanage as well but I decided to start with a standard sized pulley then move onto the larger pulley injectors and emanage. Anyway, I was meant to be given a smaller pulley but have been let down so has anyone got one please? From what I know the standard pulleys are 130mm I believe. I know that merc pulleys are slightly larger so maybe one of those would do as well but I don't know if I could run one with standard injectors.
reganlives
06-08-2020, 05:19 AM #1
06-08-2020, 06:13 AM
Standard is 130mm, and from memory I think the Merc ones are 138mm. So how much of a step down that is depends on what counts at 'stage 2'...
06-08-2020, 06:13 AM #2
reganlives
06-08-2020, 07:29 AM
I've not actually measured the pulley I have but if I'm correct its 160mm so would be a fair step down. Will I be able to run a merc pulley with standard injectors and an fcd safely?
reganlives
06-08-2020, 07:29 AM #3
06-08-2020, 07:36 AM
Should be fine as long as you're not constantly red lining it.
Sent from my Xperia S using Tapatalk 4
06-08-2020, 07:36 AM #4
reganlives
06-08-2020, 07:55 AM
Cheers. Is it a crank or water pump pulley I need and off which model merc?
reganlives
06-08-2020, 07:55 AM #5
06-08-2020, 08:31 AM
Will be the water pulley I think
06-08-2020, 08:31 AM #6
phaebo
06-08-2020, 11:50 PM
Hi i have a spare 130 mm pulley but i am looking for a 160 mm pulley.
Maybe we can make a deal that i get the 160mmand you get my 130 mm pulley
phaebo
06-08-2020, 11:50 PM #7
reganlives
07-08-2020, 01:08 AM
Sounds like a possible plan mate. I'll double check the pulley and let you know.
reganlives
07-08-2020, 01:08 AM #8
phaebo
07-08-2020, 11:30 PM
Oke let me know. You can also send a private message.
phaebo
07-08-2020, 11:30 PM #9
08-08-2020, 06:12 AM
seen the price this dudes selling pulleys at :blink:Confusedhock: http://www.ebay.co.uk/itm/Lexus-is200-Su...1075wt_932
08-08-2020, 06:12 AM #10
Views 227
21-09-2023, 03:47 PM
Views 199
15-02-2023, 10:13 PM
Views 283
13-12-2022, 05:46 AM
Views 1,503
26-11-2022, 09:36 PM
Views 141
12-07-2022, 04:45 PM
Views 182
16-06-2022, 04:29 AM
Views 139
18-07-2021, 06:41 AM
Last Post by Xtremist
Views 272
14-03-2021, 12:15 PM
Views 232
10-03-2021, 10:47 AM
Views 144
13-12-2020, 11:56 PM
