JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning oil temp, oil press, water temp and boost gauges fitting
gsitlv
06-12-2020, 05:10 PM
Im ok with boost gauge, but what about other ones and what parts I will need and where to fit them in is200. Thanks for any help
gsitlv
06-12-2020, 05:10 PM #1
07-12-2020, 03:49 AM
Afr gauge is always a good shout.
As for installs there is a rare greddy dual 60mm a pillar pod
There is adapters for above the vents but they're pricey. Alternatively make one yourself.
07-12-2020, 03:49 AM #2
gsitlv
09-12-2020, 01:54 AM
afr on the cards as well, im ok with fittings inside car, but i mean adapters on engine
gsitlv
09-12-2020, 01:54 AM #3
09-12-2020, 04:24 AM
for oil pressure and temp you can get the adapters that fit in place of the oil filter though you need a shorter oil filter as people claim somehow theres no space (but my gte block is nearly identical and i used to run 2 sandwich plates and a larger filter no problem)
water temp you can get an inline adapter for the pipe that allows you to fit a sensor, AFR will need a bung welding on
09-12-2020, 04:24 AM #4
gsitlv
09-12-2020, 02:56 PM
Thanks for your help Wink
gsitlv
09-12-2020, 02:56 PM #5
13-12-2020, 12:59 AM
Have you checked out the gauges offered by our sponsor on the site Digital Guages they have some cracking kit
13-12-2020, 12:59 AM #6
Views 873
21-01-2022, 07:36 AM
Last Post by JapHappyScott
Replies 41
Views 2,034
18-06-2020, 09:53 AM
Last Post by john wan
Replies 34
Views 1,987
12-09-2018, 02:21 PM
Last Post by Rolex
Views 631
18-05-2018, 01:25 PM
Views 604
13-02-2018, 10:09 AM
Last Post by LEX11S
Views 1,049
04-06-2016, 07:12 AM
