fitting apexi boost control
anybody fitted one of these to the turbo set up, need to find out how it plumbs in with the wastegate and bov
sorry, external wastegate. if it help i can draw a little plan of how the car is set up
'com' on the solenoid goes directly to the top port on the wastegate, 'nc' goes to the side port on wastegate, and this pipe needs a 't' peice fitting into it which goes to a pressure source between the turbo and inlet manifold. i normally fit a barb into the pipe that comes out of the turbo comressor.
also if you need assistance on setting up, give me a shout, i use these controllers all the time. they are fantastic when set up right.
And, i'd recommend fitting the purple wire onto the rpm signal from ecu rather than using it for injector duty cycle. this way you can use the 'learn' function of the avcr to it full potential.
ok but then the t piece goes to the vacum line for the bov and boost gaugeand to the throttle body and fuel pressure regulator? is this ok
yeah you can use that one, so long as its a positive pressure feed when the car is on boost as the wastegate needs the pressure on it.
the reason i normally fit a barb/nipple in the pipe right after the turbo outlet is to ensure you're getting pressure to the wastegate as instantly as poss.
i can take a picture of it to morrow and show you what i have and were it goes to. as i nned to remove the old boost controller and fit the new bov
thats the one, thats why i wanted to check how it all will fit together
