JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Heater control led guide
Pages (8): 1 2 3 4 58 Next
reco2k
20-12-2019, 06:16 PM
Hopefully this is the right are but here is a quick write up on how i did my heater controls.
Start by removing the controls and removing the rear casing via the 4 screws. You then need to remove the 5 oem bulbs 3 for the dials and 2 for the clock
[Image: 59f3cafb-5075-8d57.jpg]
Next remove the circuit board by taking out the two screws from the small panel top left (hazards) and the two more on the main board holding it in. Once out remove the 2 screws from each dial and carefully remove them making sure that you dont loose the metal contacts as they are not attached. This then allows you to remove the light guide
[Image: 59f3cafb-510a-8c03.jpg]
Next you need 4 3mm red leds i used super bright ones from Maplins which were 64p each
[Image: 59f3cafb-513c-a01b.jpg]
Then swap the 4 leds on the board for the red ones making sure the polarity is correct else you wont know when things are on or off lol.
I bought off ebay a 5 meter strip of white smds which are seperatable every 3 smds
[Image: 59f3cafb-527b-f90f.jpg]
This cost £13.99 and was a great solution as it is insulated and is for a 12v supply as well.
[Image: 59f3cafb-51c5-597f.jpg]
These then need to the organised around the board in the following pattern
[Image: 59f3cafb-5257-fc52.jpg]
[Image: 59f3cafb-53ba-2664.jpg]
Now to do each of the dials i cut into the insulation and then folded the strips of 3 so that 2 of the are facing into the switch and hot glued them in place (a hot glue gun is essential to make all this work)
[Image: 59f3cafb-530b-64c6.jpg]
Then re attach the 3 dials ensuring the the trailing end of the strip doesnt foul the button opperation in any way and these are now done.
Now proceed to lay out the remaining strips using hot glue to cover and bar components on the board protecting from short circuits.
[Image: 59f3cafb-5399-1082.jpg]
The whole lot is then wired together starting at one end and working round to the other end. Then on one of the strips closest to a light hole add an extra wire for the 12v feed and the earth. Here is a pic of it all in place
[Image: 59f3cafb-5477-73a8.jpg]
Finally remove the oem bulbs from the holders that came out from the clock and a 3mm led will fit in fine and can be wired uo ensuring that a resistor is added for a 12v supply.
[Image: 59f3cafb-549a-41fa.jpg]
[Image: 59f3cafb-54f4-6a16.jpg]
Now the casing needs to be trimmed in places to ensure that nothing fouls (be careful when trimming as if it pulls on the fromt you will damage the fascia and it can be seen from the front.
[Image: 59f3cafb-5564-f8fa.jpg]
[Image: 59f3cafb-557c-576b.jpg]
Once all fitted back in i wired it all together so was left with 1 live and 1 earth coming out of the unit and re fitted it to the switched live from the lights.
Finished product with red switch lights
[Image: 59f3cafb-55cc-e37e.jpg]
Apologies for the couple of upside down pics this is all off my phone lol
reco2k
20-12-2019, 06:16 PM #1
reco2k
20-12-2019, 06:26 PM
Pics of lay out the right way round
[Image: 20120130_162348.jpg]
[Image: 20120130_162420.jpg]
reco2k
20-12-2019, 06:26 PM #2
20-12-2019, 06:27 PM
nice write up!
20-12-2019, 06:27 PM #3
nice write up!
reco2k
20-12-2019, 06:51 PM
Thanks will add the link to the parts i bought tomorrow, have another unit which is faulty (wont blow hot) if anyone wants to take the insides out and transplant it into their own unit all wired up and ready to go
reco2k
20-12-2019, 06:51 PM #4
reco2k
20-12-2019, 07:34 PM
Marsdendean ^ How much roughly would you be looking :p
Just unsure on some of the wiring!
EDIT: Just thought you can't sell as your not an outlaw :Bazza:
Not looking to sell mate, can remove the smd's and send em to you as the are ready wired for you to fit if you want, drop me a pm if u like :-)
Will be becoming an outlaw this month me thinks :-)
reco2k
20-12-2019, 07:34 PM #5
Kevpr
20-12-2019, 07:44 PM
Nice guide, never thought of using smd strips.
Kevpr
20-12-2019, 07:44 PM #6
reco2k
20-12-2019, 07:48 PM
Kevpr Nice guide, never thought of using smd strips.
I tried 3 or 4 times with LED's in different configurations and ended up breaking the like guide trying to get an even light spread and getting rid of all the short circuits and fitting in all the wiring... Eventually I got annoyed with it and sat looking for alternative choices and stumbled on these, didn't know if it would work but thought it was worth a shot :-)
reco2k
20-12-2019, 07:48 PM #7
20-12-2019, 09:01 PM
awesome, I'd love a set like this with some blue lights in the switches! Nice work!
20-12-2019, 09:01 PM #8
21-12-2019, 03:41 AM
looks good, i started on the next ones at mine last week
21-12-2019, 03:41 AM #9
jomo
21-12-2019, 03:13 PM
Looks very nice, did you try it with just swapping the bulbs with leds bulbs in white first?
If so who did it look?
I was think of just swapping bulbs with led one's.
jomo
21-12-2019, 03:13 PM #10
Views 1,070
12-03-2022, 04:57 PM
Views 1,158
24-07-2020, 05:47 PM
Last Post by lex2oos
Views 1,237
18-05-2019, 07:13 PM
