JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Ball joints
Ball joints
Ball joints
reganlives
01-02-2021, 06:11 AM
Just got the lex mot'd this morning and she passed but got an advisory on some play on the front nearside ball joint. I remember this being a common issue but what will this do to my car? Make the handling a bit dodgy I guess? The car needs its Geo doing so will probs get both sides done then the Geo
reganlives
01-02-2021, 06:11 AM #1
lex2oos
05-02-2021, 04:45 AM
handling can be bad, uneven tyre wear, knocking, clunking sounds...
worst that can happen - and it did happen for some drivers - ball joint pops out and you will end up like this:
[Image: DSC02575.jpg]
and you dont want that...
lex2oos
05-02-2021, 04:45 AM #2
reganlives
05-02-2021, 05:16 AM
Ouch! Now I really don't want that!! Recently I've felt the car to be a bit light at the front end so I'll get both sides done asap. I assume both sides should be done at the same time?
reganlives
05-02-2021, 05:16 AM #3
lex2oos
05-02-2021, 05:41 AM
it is recomended, but it is not necessary. ask someone to inspect the other, because if its still good it can last 6k or even 20k+ miles, so no point of changing a good part. or you can just change both and forget about them for a good period of time
Wheels should be aligned after that
lex2oos
05-02-2021, 05:41 AM #4
rob
05-02-2021, 11:33 AM
And when putting the new ones back in use a bit of grease on the taper. Easier to remove in future.
rob
05-02-2021, 11:33 AM #5
reganlives
05-02-2021, 11:51 AM
Thanks guys Smile
reganlives
05-02-2021, 11:51 AM #6
Thanks guys Smile
196
31-03-2021, 07:55 AM
I just bought the tool to remove mine must be something in the air Smile
lexusdaydreaming
31-03-2021, 07:55 AM #7
phaebo
31-03-2021, 08:56 AM
I do really advice oem toyota ball joints. I had replaced them for some cheap ebay ones and after 6 months there was allready some play on the balljoints. So then i replaced them and bought oem ball joints. Now driving for a year and no play on it
phaebo
31-03-2021, 08:56 AM #8
rob
01-07-2021, 07:05 AM
Its been 4 years and 60k miles since fitting my ebay ones.. no wear all solid. At the state run car inspection center they have a machine to test ball joints with computerised outputs. Result was zero movement
rob
01-07-2021, 07:05 AM #9
reganlives
01-07-2021, 07:14 AM
Got them both changed for blueprint ones at the start of July and the car is totally different now! Drives like new with no knocking at all. Need to get my Geo done yet though and still got the light floaty feeling at speed so will look into that next and also change the drop links
reganlives
01-07-2021, 07:14 AM #10
Views 168
18-06-2020, 12:09 AM
Last Post by Jaminglish
Views 326
03-09-2018, 02:06 PM
Last Post by ydooh
Replies 35
Views 2,185
03-01-2018, 03:00 AM
