JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza front upper ball joint
ydooh
03-09-2018, 10:05 AM
I need to change the upper ball joint(front) on my is200
and have seen some on e-bay.
http://cgi.ebay.co.u...d=p5197.c0.m619
But i cannot see how you remove the old ball joint and replace it with the new one.
Has anyone done this before so i know what to do
Any help greatfully accepted
Cheers
ydooh
03-09-2018, 10:05 AM #1
Cheers
Talisker
03-09-2018, 10:13 AM
The link doesn't work buddy.
Talisker
03-09-2018, 10:13 AM #2
ydooh
03-09-2018, 11:22 AM
sorry
try this one
http://www.ebay.co.uk/itm/320628969131?s...1423.l2649
Talisker
03-09-2018, 11:33 AM
I thought the upper suspension arm with the ball joint was a complete assembly. It might be possible to replace the balljoint in the arm but I suspect you will need a hydraulic press in order to install it.
Someone on here might know different though.
Talisker
03-09-2018, 11:33 AM #4
03-09-2018, 11:34 AM
by the looks of the kit you'd remove the circlip and it should come out.
03-09-2018, 11:34 AM #5
03-09-2018, 11:57 AM
remove the arm then remove the circlip then if you can get to a vice open the jaws slightly wider than the ball joint place the arm on top and give a good smack with a hammer job done and same to put back in,or take the arm to a garage and ask them to press it out and press the new one in
03-09-2018, 11:57 AM #6
ydooh
03-09-2018, 02:06 PM
Cheers for that Ormi
:thumbup1::thumbup1:
ydooh
03-09-2018, 02:06 PM #7
Views 419
01-07-2021, 07:14 AM
Last Post by reganlives
Views 180
01-07-2020, 04:42 AM
Views 168
18-06-2020, 12:09 AM
Last Post by Jaminglish
Views 564
02-08-2019, 08:39 AM
Last Post by jasons
Views 290
28-07-2019, 04:57 AM
Last Post by Matt_C
Views 310
19-07-2019, 12:48 PM
Last Post by Chris0121
Views 765
01-04-2019, 04:02 AM
Last Post by lookatmybiceps
Views 338
15-01-2019, 05:15 AM
Last Post by avi_444
Views 1,040
28-11-2018, 10:22 AM
Last Post by sprinter2012
