JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Front Fog Lights
Front Fog Lights
Front Fog Lights
Pages (3): 1 2 3 Next
LEXOB
25-11-2018, 01:34 PM
I was just wondering if anyone can tell me if there are any differences in the types of front fog lights used on the IS200?
I know around 2003> they changed to the darker colour and different bulb type. But was that it?
The reason why I ask if i'm about to fit my third set, simply due to the fact that they keep corroding! They get condensation in, water gets in and the bulbs corrodes in the back of the unit. Very frustrating and very expensive!!
My question is, is there meant to be some sort of protection like a rubber water proof cover on the backs? Did Lexus modify the later spec fog lights?
And is it only the darker ones that take the different bulbs?
Cheers
LEXOB
25-11-2018, 01:34 PM #1
Cheers
25-11-2018, 02:20 PM
All is300s do have a yellow film behind the projector to make the bulb yellow Gord
25-11-2018, 02:20 PM #2
25-11-2018, 02:24 PM
they did change the bulbs older ones used hb4 then they changed them
the newer ones ran h3's
Edited 07-01-2012, 12:03 AM by ormi.
25-11-2018, 02:24 PM #3
LEXOB
25-11-2018, 03:08 PM
How would you wire up the late spec fogs to run them on earlier spec cars?
LEXOB
25-11-2018, 03:08 PM #4
25-11-2018, 03:09 PM
myself i would make a short loom so i didnt need to butcher the standard loom
25-11-2018, 03:09 PM #5
LEXOB
25-11-2018, 03:12 PM
Mate I am **** with wiring I wouldn't even attempt it. I'd probably understand what to do but I wouldn't risk it.
LEXOB
25-11-2018, 03:12 PM #6
25-11-2018, 03:16 PM
mate theirs only two wires and you cant even muck them up
25-11-2018, 03:16 PM #7
LEXOB
25-11-2018, 03:24 PM
So is it a common fault that they keep corroding or am I just unlucky?
LEXOB
25-11-2018, 03:24 PM #8
25-11-2018, 03:26 PM
Common fault, water gets into the earlier style ones. Plus salt water isn't good for aluminium anyway.
The ones I have (post 03) have a H3 style bulb, with a plastic cap and a rubber seal over the back so the whole thing is water proof.
Edited 07-01-2012, 01:01 AM by sprinter2012.
25-11-2018, 03:26 PM #9
27-11-2018, 02:10 AM
Correct me if I am wrong, I think Landrovers have a breather hole + rubber tube on the top of their fog lights do they not? This would allow the water that does get in through the seals to escape in the form of steam through the rubber hose as the lamp heats up the unwanted water???
Would this be a viable option to solve the IS200's fogs misting up?
27-11-2018, 02:10 AM #10
Views 204
07-10-2020, 01:46 AM
Last Post by Stoney
Views 233
01-07-2020, 04:42 AM
Views 722
02-08-2019, 08:39 AM
Last Post by jasons
Views 321
28-07-2019, 04:57 AM
Last Post by Matt_C
Views 346
19-07-2019, 12:48 PM
Last Post by Chris0121
Views 921
01-04-2019, 04:02 AM
Last Post by lookatmybiceps
Views 384
15-01-2019, 05:15 AM
Last Post by avi_444
