JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Has anyone got is300 lights fitted to their is200
Pages (3): 1 2 3 Next
07-07-2018, 05:24 AM
right here goes ive got a few ideas for the car right i know i said that was it....ive got two plans
fit is300 hid lights sick of mine steaming up and their is some place to hide the balasts...ie the space in the bottom of the lights..and the bonus they are dark so has anyone done that?
and two...
buy one of those rear mirror monitors(the ones you can connect to the dvd player) strip it down and fit it to the standard oe mirror...has anyone done that?....
07-07-2018, 05:24 AM #1
and two...
07-07-2018, 05:27 AM
People have fitted 300 lights, I think they need to be modified to fit, but that shouldn't be a problem for you. You were thinking of UK spec 300 lights I assume?
The mirror idea is an interesting one, for reversing camera, but not see it done myself.
Edited 18-08-2011, 03:02 PM by Stoney.
07-07-2018, 05:27 AM #2
07-07-2018, 05:28 AM
IIRC in previous discussions about the IS300 lights, the actual shape of the light is the same, but theres a tab somewhere or a bit of panel that clashes. So with a small modification they will fit.
07-07-2018, 05:28 AM #3
07-07-2018, 06:01 AM
all the new toyotas come with the reverse cam in the mirror i just want the monitor to play dvds just for the novelty...lol
07-07-2018, 06:01 AM #4
07-07-2018, 07:28 AM
iirc some of the inner wing needs to be cut away to make them fit, member on the otherside had done this years ago, deffo can be done!
07-07-2018, 07:28 AM #5
Rolex
08-07-2018, 09:49 PM
Matt Crawley from the LOC fitted IS300 lights to his IS200. Radiator Bracket needs modification to fit the lights and you will need to transplant the loom from is300 to is200 but apart from that its pretty much straight forward IIRC.
Rolex
08-07-2018, 09:49 PM #6
08-07-2018, 09:55 PM
i have a set of lights but no ballests and the steam up after i put halo rings in them and from a lhd car
08-07-2018, 09:55 PM #7
09-07-2018, 05:02 AM
Rolex Matt Crawley from the LOC fitted IS300 lights to his IS200. Radiator Bracket needs modification to fit the lights and you will need to transplant the loom from is300 to is200 but apart from that its pretty much straight forward IIRC.
do you even need to swap the loom if your using your own hid kits?(well i'll need diff bulbs but ill be using the kits i have)
09-07-2018, 05:02 AM #8
Phil01
09-07-2018, 12:26 PM
if you are using your old kit you will need 2 of these.
http://www.ebay.co.uk/itm/PAIR-D2S-D2R-S..._500wt_922
And 2 of these at what ever temp you want,
http://www.ebay.co.uk/itm/2-x-D2R-Xenon-...4aadf1f159
Phil01
09-07-2018, 12:26 PM #9
19-07-2018, 05:19 AM
That is interesting ormi I am thinking to do the same soon
19-07-2018, 05:19 AM #10
Views 329
13-12-2023, 02:06 PM
Views 468
09-11-2023, 03:46 AM
Last Post by Dinho
Views 696
06-11-2022, 01:49 AM
Views 1,164
02-11-2022, 10:55 AM
Views 305
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,133
23-02-2022, 01:20 PM
Views 352
18-10-2021, 02:04 AM
Views 455
03-09-2021, 11:04 AM
Views 488
29-08-2021, 09:59 AM
Replies 35
Views 7,699
04-08-2021, 04:34 AM
Last Post by cjoseph
