JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! supercharger help.
supercharger help.
supercharger help.
daveo
06-02-2021, 09:18 AM
can someone please help here explain a few things. the car is nearly ready for remapping. have supercharger mounted and hardpiped. i did not put anything on the bypass valve as i was thinking i could run without it.....can i run without it or am i better to install one. the cable off of the valve is broken but the spring is ok. do i have to replace this cord?? the car is drift spec .i am using a patrick black box. will this be ok with a 160mm pulley.?? any help greatly appreciated as im at a standstill at the moment.
daveo
06-02-2021, 09:18 AM #1
reganlives
06-02-2021, 11:17 AM
You will need to uprate your injectors to run a larger pulley and in place of a bypass could have a blow off valve.
reganlives
06-02-2021, 11:17 AM #2
daveo
06-02-2021, 11:22 AM
i would leave the bypass open so and put a blow off valve over off of the trottle body ??
are you sure i need uprated injectors?? thought it would run fine with a fuel pressure reg??
daveo
06-02-2021, 11:22 AM #3
reganlives
06-02-2021, 11:48 AM
Not 100% sure on the location of the bov. Mine is near the inter cooler just behind the bumper but my supercharger isn't running yet as still need a couple of bits but otherwise its all fitted. I'll be running a 145mm pulley and the best match for that are 1zzfe injectors. A lot of people will be able to help you mate. If you want to run a 160mm pulley though I think you may be better of with an emanage then get it fully mapped. You'all need to remove your pre cats as well as people have had them melt. There's some decat manifolds on eBay at the moment.
reganlives
06-02-2021, 11:48 AM #4
daveo
06-02-2021, 12:08 PM
i have my manifold decatted.so we are all good there.oh god.........anyone got any idea what injectors go with the 160 pulley or can i run on originals?? e manage is the plan next year just want to get drifting this year with it.
daveo
06-02-2021, 12:08 PM #5
deccie22
06-02-2021, 01:45 PM
martin ran a 160 mill pully off an e class with no probs dave! ask him! and he ran a ssqv but said on the over run it sounded mad
deccie22
06-02-2021, 01:45 PM #6
daveo
06-02-2021, 01:56 PM
is that martin in galway or cashel dec??
daveo
06-02-2021, 01:56 PM #7
deccie22
06-02-2021, 01:58 PM
galway he had the s/c blue as200
deccie22
06-02-2021, 01:58 PM #8
daveo
06-02-2021, 02:01 PM
ahhh he sold that setup didnt he?? just mailed him for a number on tezza world , cheers for that buddy
daveo
06-02-2021, 02:01 PM #9
deccie22
06-02-2021, 02:07 PM
yeah hes building another one but he said it ran good.only for him id be fooked trying to put it all together
deccie22
06-02-2021, 02:07 PM #10
Replies 209
Views 26,225
06-04-2024, 05:29 PM
Last Post by lexus971
Views 1,709
21-03-2024, 04:36 PM
Views 1,163
29-08-2020, 10:01 AM
Views 1,173
12-09-2019, 12:32 PM
Views 964
10-06-2019, 10:02 AM
