JapCarForum Car Manufacturers Toyota Rev2 turbo
Rev2 turbo
Rev2 turbo
is200turbo
18-02-2021, 09:54 AM
Had anyone on here got or had a rev2 turbo mr2as mine is having a few issues.
The main issue is that it's boiling over even with no thermostat in, it's bled properly as there a pain 2 do so I took my time ( bout an hour) but even on tick over with no cap on its like a fountain the temp never goes above half way.
The second issue it seams to be always on choke (1200ish rpm) and misses slightly when you rev it.
I'm taking it back to the specialist next week for a few more bits sorting out but want to try and sort this so I can test it first.
is200turbo
18-02-2021, 09:54 AM #1
john wan
18-02-2021, 12:11 PM
Sounds like head gasket mate you checked the oil?
john wan
18-02-2021, 12:11 PM #2
is200turbo
18-02-2021, 12:22 PM
Yeah it's all good I'm goin 2 try bleeding it again in the mornin as I can't remember if the rad was hot after I bled it
is200turbo
18-02-2021, 12:22 PM #3
john wan
18-02-2021, 08:14 PM
Should maybe check there isnt a blockage to then ie rad or the thermostat isnt sticking mate
john wan
18-02-2021, 08:14 PM #4
is200turbo
18-02-2021, 10:20 PM
There is no thermostat In mate , I'm just hoping it's not the head gasket or a cracked block
is200turbo
18-02-2021, 10:20 PM #5
john wan
18-02-2021, 10:38 PM
Id check the rad mate ive had a blocked one before that made it act like that eh
john wan
18-02-2021, 10:38 PM #6
is200turbo
18-02-2021, 10:43 PM
In goin to check that this mornin mate cheers
is200turbo
18-02-2021, 10:43 PM #7
Views 1,048
16-10-2019, 01:09 AM
Views 763
26-09-2018, 04:02 AM
Last Post by Chris0121
Views 536
20-02-2018, 10:25 AM
Views 667
29-07-2017, 10:12 PM
Last Post by TimmyK
Views 992
13-07-2017, 10:48 PM
Last Post by TimmyK
Replies 58
Views 3,485
26-04-2017, 10:18 AM
Last Post by Dan_Turism0
