JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications lexus is 200 tte compressor problem
Alpine89
22-04-2021, 11:27 AM
Have trouble getting the kit to work. The wire is ner and it may not follow the throttle optimally. It came off when it reached the end position of the compressor before the throttle.
How do I set it up easiest? Gladly picture if available.
:Sulk:
Alpine89
22-04-2021, 11:27 AM #1
:Sulk:
Alpine89
22-04-2021, 11:28 AM
Wire is new*
Alpine89
22-04-2021, 11:28 AM #2
Wire is new*
22-04-2021, 01:32 PM
The wire should be loose really,
The throttle should shut and the wire only just closed
22-04-2021, 01:32 PM #3
Alpine89
22-04-2021, 06:19 PM
Thanks for answer!
Something like this at idle? The damper to the bypass pipe should well be completely closed for the pressure to be built up. Recordings have to be full throttle to get the power from the compressor well? Notify me please.
Pic:
http://www.ladda-upp.se/bilder/wqqsocesmqjtbs/
Alpine89
22-04-2021, 06:19 PM #4
Thanks for answer!
Pic:
22-04-2021, 10:58 PM
That looks about right. But you don't appear to have a return spring on the bypass
Edit: just noticed the spring. How worn is that? The later tte design went to a clock spring instead.
Edited 04-06-2014, 08:33 AM by Sparkystav.
22-04-2021, 10:58 PM #5
Alpine89
22-04-2021, 11:29 PM
I've cut the spring so it spans more which I guess it must be?
I disconnected the cable and shut the damper to the bypass pipe but there will be no pressure so wonder if it's more trouble than cable? Will not that be pressure on the gauge when pressing accelerator to the floor, now I see only the pressure when I release the gas pedal.
Feels like original power now..
Running out of ideas: (
Alpine89
22-04-2021, 11:29 PM #6
Alpine89
23-04-2021, 07:33 AM
Compressor is broken? I bought the kit of a person in the last week.
Bought new cable and tweaked it good but had in mind that it was not the fault ...
When the return valve closes and the full throttle, I get NO charge at all. I only see that it jumps up to 0.5 bar when I RELEASES on the accelerator for a second.
Normally it should be vacuum at idle and then boost as long as I push the gas.
Could there be something wrong with the compressor and what in that case?
Alpine89
23-04-2021, 07:33 AM #7
23-04-2021, 09:11 AM
You should only get boost on load really. You get the spike because the throttle closes before the bypass opens.
Is the clutch engaged/ or the screw in it?
23-04-2021, 09:11 AM #8
Alpine89
23-04-2021, 09:56 AM
Should I not be able to see the boost pressure when I gas? : Shock:
Do you mean the clutch at the pulley for the compressor? Then I have no idea how to check it.
Can hear the air being sucked into the filter when the damper is fully open to the compressor. So, even I thought it might be something that did not really grip in there ..
Alpine89
23-04-2021, 09:56 AM #9
23-04-2021, 12:44 PM
I'm confused by 'damper fully open to the compressor"? The valve should shut as the throttle is opened, closing the bypass and forcing the air the charger is sucking towards the engine instead of back round
23-04-2021, 12:44 PM #10
Views 396
30-04-2022, 06:27 AM
Views 755
09-08-2021, 10:35 PM
Last Post by Jimbob-T-Lex
Views 266
07-03-2020, 12:49 PM
Views 931
02-04-2019, 09:04 AM
Views 663
28-03-2018, 03:07 PM
Last Post by ormi
Views 461
30-01-2018, 10:59 AM
Last Post by SXE10STU
Replies 29
Views 1,713
25-12-2017, 08:05 AM
Replies 56
Views 3,741
19-03-2017, 10:38 PM
