JapCarForum Cars, Cars, Cars! General Car Maintenance light stalk wiring!
light stalk wiring!
light stalk wiring!
stiggy
08-08-2016, 08:12 AM
HELLLLLLLLLLLP:confused1:
has any got a wiring diagram for the headlights/indicator stalk for a is200 X plate??????
as having made my own loom for the skiding lexus it only the light stalk to sort!!
thanking you pleaseBig GrinWink
stiggy
08-08-2016, 08:12 AM #1
08-08-2016, 08:14 AM
Have you looked here:
bahamutcars.com/workshop/IS_98-05/index.html
Theres system wiring diagrams on there.
08-08-2016, 08:14 AM #2
stiggy
08-08-2016, 08:17 AM
nope but ill try:thumbup1:
me an computers ya see:Chair::Chair:
stiggy
08-08-2016, 08:17 AM #3
08-08-2016, 08:18 AM
http://www.bahamutcars.com/workshop/IS_9...=tshwl-rhd - Indicators
http://www.bahamutcars.com/workshop/IS_9...ode=hl-rhd- Headlight control
http://www.bahamutcars.com/workshop/IS_9...-11672.pdf - Connector for them both
Them two should help
08-08-2016, 08:18 AM #4
08-08-2016, 08:20 AM
they should be exactly what you need
08-08-2016, 08:20 AM #5
stiggy
08-08-2016, 01:08 PM
thanking you :thumbup::thumbup:
ah nope cant read/access that just comes up all coded gobbelydy goop
Edited 19-09-2009, 10:45 PM by stiggy.
stiggy
08-08-2016, 01:08 PM #6
08-08-2016, 02:48 PM
the links wont work in Chrome or Firefox.
You have to open them in Internet explorer then they should work
08-08-2016, 02:48 PM #7
09-08-2016, 01:13 AM
They're PDF (Acrobat) documents, if you've got a problem with your reader for that then that might cause problems.
As Stav said it should work fine in Internet Explorer. In the worst case, if you can't get them to display at all, I'm sure we could email them to you or do something else to help you out (e.g. if you have some specific questions we could answer from the diagrams).
09-08-2016, 01:13 AM #8
stiggy
13-08-2016, 12:14 PM
i have the stalk and about 6" of wirin loom,
ive run all the wires from revelent lights to under dash,now its connectin them all up.....except inner main beam as thats on a seperate switch!!
so i need live in feed wire color?
and what color wires to revelent lights?/relays etc!
headlight elec adjusters not req tho!!!!
any help much appreciatedBig Grin
stiggy
13-08-2016, 12:14 PM #9
13-08-2016, 11:53 PM
If you PM me your email address I could try emailing you the wiring diagrams. They're in Adobe PDF format (Acrobat Reader). That would probably be easier for you, but I'll try to describe what's on the diagram, feel free to ask more questions. The wiring diagrams for the IS200 are very good and tell you everything you'll need to know ! :biggrin:
For the indicators, the common wire is white with a black stripe, and that goes from the indicator stalk to a common connector which is earthed. Then for left turn, the wire is pink with a green stripe, and that goes to pin 8 of the flasher relay. For right turn it's a green wire with yellow stripe, and that goes to pin 6 of the flasher relay.
Are the lights on the dash still wired up as originally or do you need that info too ? e.g. the turn lights on the dash ?
The headlamp wiring is more complicated with the different switch combinations, but I wanted to check I'm giving you the right sort of info before getting into that.
13-08-2016, 11:53 PM #10
Views 582
05-03-2023, 01:41 PM
Views 899
08-07-2019, 05:18 AM
Last Post by Dark Samurai
Views 300
22-05-2019, 10:33 AM
Last Post by is300_dino
Views 707
25-02-2019, 08:24 AM
Views 888
04-01-2019, 03:34 AM
Views 679
18-05-2016, 02:10 AM
Last Post by Saraj
