TRC flashing and ABS light on!!!!!!!!
hi guys its been awhile since ive last posted how have you all been anyway the other night i was driving home when i hit a pot hole the steering started to go on one side so i thought to myself its the tracking thats been knocked but just about another mille down the road i went over a speed bump n snap the driver side suspension just clopased on me i had no control as i manged to drag/drive the car to the side i had noticesed that my ball joint had snappped clean off cut the story short i have had them both replaced but im having a problem I dont have TRC anymore and also i dont have ABS no more and its quite scary since its been snowing heavily any help plz guys much appreciated....:thumbup1:
Youll have broken snapped the ABS sensor.
has you had a look at it?
yes as both the traction control and ABS need that signal to work properly.
depends how much you can find a sensor for i suppose
toxo Wonder if that's the same deal as what happened to Ormi's balljoint!
SENSOR, SPEED, FRONT RH
89542‑51010 1 € 244.42
Probably best to try and find one from a breaker!
If you take the wheel off you'll see there are 2 'pipes/wires' coming out from the car to the wheel hub.
1 is the brake line, this goes into the brake caliper and is a flexible rubber hose
The remaining one is the one you want, it goes into the hub itself near where the suspension turret joins the hub. It bolts in and the wire goes up the side of the wheel arch to behind the plastic arch liner where there is a wiring connector you can unclip to separate the ABS sensor and its wire from the rest of the car. The cable is held in with a couple of 10mm bolts to the wheel arch and 1 bolting the sensor in to the hub.
They take a bit of effort to get out of the hub.
Why not try? It's broken anyway what have you got to lose?
