JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Remote boot popper
Remote boot popper
Remote boot popper
ZAIS200
14-07-2021, 04:33 AM
Hi guys,
I was going through some past projects and i noticed it mentioned a few times but can't actually find a how to with pictures or wiring diagram to do the remote boot popper, when mentioning it briefly to Rabster once he suggest i buy some relays which i did do but then i moved and forgot about it, any way was wondering if anyone here could drop a link to a how to to wire up the remote boot popper.
Thanks in advanse,
ZAIS200
14-07-2021, 04:33 AM #1
Hi guys,
Thanks in advanse,
14-07-2021, 05:33 AM
How you mean mate? As the key should pop the boot, or the lever in the car
14-07-2021, 05:33 AM #2
14-07-2021, 05:49 AM
Think he was doing aftermarket alarm or did install?
14-07-2021, 05:49 AM #3
ZAIS200
14-07-2021, 06:28 AM
Rabster Think he was doing aftermarket alarm or did install?
Exactly right Rabster...
@Sparkystav - I installed an aftermarket alarm into the car 'cos the key fob was knackered so the remote for the alarm as a function to pop the boot and when i mentioned irt to Rabster he said to pull it of i needed a relay which i've since bought but forgot about doing it.
So now i'm trying to find a wiring diagram to fit this lot to my car, so when i push the remote button the boot pops open...
ZAIS200
14-07-2021, 06:28 AM #4
14-07-2021, 06:32 AM
You need the wiring for the alarm, there is a relay in the boot from the standard popper, but it depends on the alarm output. Need to know if it's negative (ground) or positive (12v)
14-07-2021, 06:32 AM #5
14-07-2021, 10:57 AM
I think I still got the wiring details from your alarm.will look it up in morning
14-07-2021, 10:57 AM #6
ZAIS200
14-07-2021, 01:47 PM
Rabster I think I still got the wiring details from your alarm.will look it up in morning
Great Rabster that would help actually as the diagram i had went missing in the move... :blushing:
ZAIS200
14-07-2021, 01:47 PM #7
ZAIS200
04-12-2021, 05:22 AM
Hi Guys managed to find a diagram, it looks like the boot popper is a negative trigger, does this help?
ZAIS200
04-12-2021, 05:22 AM #8
04-12-2021, 09:10 AM
The boot is positive trigger to the relay
04-12-2021, 09:10 AM #9
Views 481
21-05-2023, 08:43 AM
Views 633
30-03-2021, 03:12 AM
Last Post by Millo73
Replies 23
Views 1,901
21-10-2020, 07:19 AM
Replies 22
Views 1,594
22-04-2018, 04:59 AM
Replies 51
Views 3,373
09-09-2016, 06:30 AM
