JapCarForum Car Manufacturers Lexus/Toyota Strange coolant issue
Pages (3): 1 2 3 Next
is200turbo
15-09-2021, 04:08 AM
I've just fitted a new thermostat on my is200 and all bled up fine , up to temp and fans came on.
When I'm out drivin the temp gauge drops down to quarter warm but when I park up it goes back to normal, but only half the rad is warm now, I've re-bled the system and still no trapped air.
I'm totally stumped now.
is200turbo
15-09-2021, 04:08 AM #1
15-09-2021, 05:50 AM
hmm that sounds odd for sure. ill have a think but stav or someone like that maybe be able to help
15-09-2021, 05:50 AM #2
15-09-2021, 12:20 PM
Sounds like thermostat stuck open to me
15-09-2021, 12:20 PM #3
is200turbo
15-09-2021, 01:26 PM
It's brand new as that was the issue before I changed it, it's not as bad but still an issue could it be the rad or rad cap?
is200turbo
15-09-2021, 01:26 PM #4
is200turbo
09-10-2021, 09:26 AM
Will I've changed the rad cap and it still the same, there has got to be a leak some where as I've had to top up the coolant so hope the replacement rad fixes the issue
is200turbo
09-10-2021, 09:26 AM #5
09-10-2021, 09:33 AM
Have you looked at the thermostat?
Cheaper than buying a rad
Edited 20-11-2014, 07:07 PM by Sparkystav.
09-10-2021, 09:33 AM #6
is200turbo
09-10-2021, 09:36 AM
I've changed the stat it was the first thing I did mate, the rad is stained red from the coolant and the under tray looks wet all the time under the rad so I'm guessing it has a leak plus it gives me an excuse to put a alu rad on Smile
is200turbo
09-10-2021, 09:36 AM #7
lex2oos
09-10-2021, 11:19 AM
check the overflow tank for cracks too, because thats where i was loosing coolant in mine.
lex2oos
09-10-2021, 11:19 AM #8
is200turbo
09-10-2021, 11:34 AM
I've checked it and it is water tight
is200turbo
09-10-2021, 11:34 AM #9
Morango
14-10-2021, 06:39 AM
it sounds like thermostat but if the problem is the same after a change maybe the coolant is bypassing the thermostat some how? gasket or crack? leaking coolant shouldn't produce the 1/4 temperature reading when moving.
Morango
14-10-2021, 06:39 AM #10
Views 447
12-11-2022, 10:30 AM
Views 232
09-05-2021, 06:12 AM
Views 355
23-09-2016, 11:25 PM
