JapCarForum Car Manufacturers Lexus/Toyota 02 Sensor Heater issue
VVT-Einstein
31-10-2021, 05:29 AM
Hi guys
I've got the EML on in my IS200 with code P0135, 02 Sensor Heater Circuit Bank 1 Sensor 1.
I've tried replacing the sensor and deleting the code but it's come back straight away. The sensor itself must be working fine as fuel consumption and such hasn't been effected at all. I understand there's a heater element built into the sensor but I imagine this is working fine in the new sensor. Any ideas what the issue could be?
Cheers!
VVT-Einstein
31-10-2021, 05:29 AM #1
Hi guys
Cheers!
01-11-2021, 11:34 AM
it could be a cooked sensor wire if you have put a new sensor in :confused:
01-11-2021, 11:34 AM #2
VVT-Einstein
05-11-2021, 11:40 AM
Yeah, that's definitely a possibility. If I use a sensor simulator that includes the heater element signal to get rid of the EML will this effect fuelling/engine running?
VVT-Einstein
05-11-2021, 11:40 AM #3
05-11-2021, 01:55 PM
On that one it will. That one helps control fuelling
05-11-2021, 01:55 PM #4
myheroduane
11-11-2022, 03:48 AM
Could be a small crack in exhaust giving false readings.
Sent from my HTC One_M8 using Tapatalk
myheroduane
11-11-2022, 03:48 AM #5
VVT-Einstein
11-11-2022, 10:48 AM
Hmm, I changed the manifold since getting the error code but it still comes on... I've kinda just resigned myself to the fact it's always on now. Engine runs fine and still get about 400 miles to a tank, just annoys me a bit that the light is always there on the dash
VVT-Einstein
11-11-2022, 10:48 AM #6
11-11-2022, 09:14 PM
There must be an issue with the wiring or Ecu if it comes on straight away. Normally the o2 sensors that a while to come back on
11-11-2022, 09:14 PM #7
VVT-Einstein
12-11-2022, 03:36 AM
Yeah, also if I delete the code while the engine is up to temperature the light stays out, but if I delete the code before it's up to temperature it comes back on...
VVT-Einstein
12-11-2022, 03:36 AM #8
12-11-2022, 10:30 AM
Could be a heater fault then with the sensor circuit
12-11-2022, 10:30 AM #9
Views 653
06-01-2024, 08:26 AM
Last Post by bigdave1701
Replies 25
Views 840
07-12-2021, 08:28 AM
Views 167
22-11-2021, 07:39 AM
Last Post by liquidlazer
Views 406
17-10-2021, 11:38 AM
Last Post by reganlives
Views 384
04-03-2020, 12:09 PM
Last Post by pauls_is200
Views 371
23-09-2016, 11:25 PM
