JapCarForum Car Manufacturers Lexus/Toyota is200 rear o2 sensor
daveb948576
29-12-2023, 02:46 AM
can i please have the required info so that i can disable the rear o2 sensor, i only have a single cat and the OBD is telling me the efficiency is below threshold, with resistors not the anti foulers, thank you
daveb948576
29-12-2023, 02:46 AM #1
29-12-2023, 02:23 PM
What cats have you removed mate?
I do a box that replaces the rear sensor to fool the ecu into thinking everything is fine.
29-12-2023, 02:23 PM #2
daveb948576
30-12-2023, 07:30 AM
i don't have any pre-cats, i only have the main cat installed, is this what is needed to sort it out? i can solder and make whatever is needed myself? i don't really want to buy a box if i can learn and build it myself but obviously i don't know what to make.
[Image: 2enatuva.jpg]
daveb948576
30-12-2023, 07:30 AM #3
30-12-2023, 08:54 AM
I'll be honest mate I'm not going to reveal what's in my simulator box as it's a product I sell. But it's certainly more components than that and i could tell you or not if that system pictured would work.
30-12-2023, 08:54 AM #4
daveb948576
30-12-2023, 09:49 AM
Marc, how much is your box?
daveb948576
30-12-2023, 09:49 AM #5
30-12-2023, 02:22 PM
£40 mate, I'll do free postage in the U.K.
30-12-2023, 02:22 PM #6
is200turbo
30-12-2023, 10:48 PM
Stav would your box work if I took 1 of the lambda out of the precats so I could fit my air/flo in its place?
is200turbo
30-12-2023, 10:48 PM #7
daveb948576
31-12-2023, 07:08 AM
i'll take a box off you please Marc.
@is200turbo, you can wire up both the front sensors to one single lambda with no issues, join the plugs wire for wire and run one 02 sensor then you'd have another hole for your wideband.
daveb948576
31-12-2023, 07:08 AM #8
31-12-2023, 09:05 AM
The only risk is with each sensor you are only measuring one 'bank' of three cylinders. But it will work
31-12-2023, 09:05 AM #9
daveb948576
01-01-2024, 03:16 AM
and there was me just assuming he had a turbo because of his name, why even add a wideband sensor to a car with pre cats?
pm's replied marc
daveb948576
01-01-2024, 03:16 AM #10
pm's replied marc
Views 378
09-10-2023, 03:21 PM
Views 422
04-10-2023, 12:38 PM
Last Post by CrocodileHunter
Replies 22
Views 1,429
27-07-2023, 11:45 AM
Replies 52
Views 3,064
14-07-2023, 09:41 PM
Last Post by Mr_Woods
Views 834
25-05-2023, 06:58 AM
Views 457
24-05-2023, 01:50 PM
Last Post by ViperTheLex
Views 695
20-05-2023, 07:02 AM
Views 600
01-05-2023, 12:16 AM
