JapCarForum Car Manufacturers Lexus/Toyota Is200 head gasket replacement
Pages (3): 1 2 3 Next
52
22-07-2024, 06:18 PM
The radiator let go on my car this morning and it seems to have taken taken the head gasket with it as it wouldn't run properly after the rad was refilled until it had cooled down sufficiently. My own fault as its been leaking a while and I've not got around to fitting a new rad
Is there anything to be careful of when doing a gasket on one of these? It all looks easy enough?
Im just hoping its not a cracked head and I'll get away with just getting it skimmed?
Any tips would be much appreciated
Thanks
CrocodileHunter
22-07-2024, 06:18 PM #1
Thanks
FOSSIL FUELS
Moderator
892
23-07-2024, 12:16 AM
Hopefully with just a light skim you'll be OK..
Have you tried and ECU reset before you do any major work... Any management lights on??
T-lex or Stav would be the best to speak to on the 1GFE engines.
[Image: Supra-logo-toyota-supras-119417_1569_512...duxjro.jpg]
Toyota Supra Aero Top... In 202 Black and 18" GOLD & Chrome's with a BGW Wink
FOSSIL FUELS
23-07-2024, 12:16 AM #2
23-07-2024, 02:41 AM
Interesting you should mention about lights.
The first indication i knew something was wrong was because the eml light came on and the traction control light started flashing. I then realised the temp gauge was reading stone cold and pulled over as soon as i could.
When recovered home about an hour or so after it happened it started like normal an i was able to reverse it onto the drive.
I'm going to fit the new rad and run it up to see what happens. I thought at the time that it was water getting onto a plug causing it to have the starting issue and the gasket might have resealed once it had cooled? Suppose I'll know soon enough if it does it again once up to temp
CrocodileHunter
23-07-2024, 02:41 AM #3
is200turbo
23-07-2024, 10:52 AM
Have you checked the thermostat?
is200turbo
23-07-2024, 10:52 AM #4
52
23-07-2024, 11:42 AM
No not yet but it lost all its coolant so i don't think there is a fault there.
Its 100% the rad that has caused all the problems, I'm just not sure if its done the HG at the moment?
What exactly does the eml and flashing trc light mean?
CrocodileHunter
23-07-2024, 11:42 AM #5
is200turbo
23-07-2024, 12:16 PM
I'm just thinking with the temp on stone cold when my rad went the temp went through the roof
is200turbo
23-07-2024, 12:16 PM #6
52
23-07-2024, 02:32 PM
Yeah thats what I'd expect too?
I can only assume that because there was no water around the gauge sender it was reading cold?
CrocodileHunter
23-07-2024, 02:32 PM #7
is200turbo
23-07-2024, 02:52 PM
The sensor on the rad is the fans I don't know if it does the gauge mate
is200turbo
23-07-2024, 02:52 PM #8
52
23-07-2024, 03:32 PM
Im going to fit the new rad tomorrow and see how it goes.
If the coolant level drops or the temp starts to increase over normal I'll know its the HG
CrocodileHunter
23-07-2024, 03:32 PM #9
23-07-2024, 07:56 PM
If it's reading cold I'd check the thermostat. That would make you loose coolant quicker as well.
The sensor would go high as the block would be hot as it's not being cooled I'd of thought.
Change the rad, check the thermostat, refill the system, reset the ecu to get rid of the warning light then see how it goes.
Check the coolant level as well once bled and run up. If you're losing coolant it could be the headgasket
23-07-2024, 07:56 PM #10
Views 1,067
06-01-2025, 09:27 PM
Last Post by liquidlazer
Views 1,343
05-01-2025, 02:15 PM
Last Post by bigdave1701
Views 1,053
06-12-2024, 06:40 PM
Last Post by Lekko
Views 617
08-10-2024, 09:10 PM
Views 804
03-10-2024, 06:27 PM
Last Post by CrocodileHunter
Replies 52
Views 4,857
14-07-2024, 03:30 AM
Last Post by Mr_Woods
Views 1,366
24-05-2024, 12:47 PM
Views 817
23-05-2024, 07:38 PM
Last Post by ViperTheLex
Views 1,083
19-05-2024, 12:51 PM
Views 1,029
30-04-2024, 06:05 AM
