JapCarForum Car Manufacturers Lexus/Toyota Lexus IS200 engine light& trc light come on dash
Lekko
03-12-2023, 08:30 AM
Auto x reg , trying to find out why my engine management light and trc light come on. Trc light flashes car runs a little lump under load takes the battery lead and efi fuses out to re set the ecu. Put new plugs in still runs lump but light have gone out only because i disconnected the battery once driving again engine and trc light came back on? Wonder if anyone has had the same problerm in the past regards kay
Lekko
03-12-2023, 08:30 AM #1
Dinho
03-12-2023, 12:38 PM
Have you plugged in an OBD scanner to see if any codes come up?
Dinho
03-12-2023, 12:38 PM #2
Lekko
03-12-2023, 01:22 PM
Hi yes i took it to a garage and he cleared it and it ran ok, but the engine management light and trc light came back on
Lekko
03-12-2023, 01:22 PM #3
Is200kid
03-12-2023, 04:27 PM
would it be misfiring bud or check the spark plugs..
Is200kid
03-12-2023, 04:27 PM #4
Lekko
03-12-2023, 11:18 PM
Ive changed the spark plugs bud still no luck
Lekko
03-12-2023, 11:18 PM #5
Dinho
05-12-2023, 07:48 AM
What codes came up when you took it at the garage?
Dinho
05-12-2023, 07:48 AM #6
06-12-2023, 11:55 AM
Yep the garage should have given you the codes
06-12-2023, 11:55 AM #7
Lekko
07-12-2023, 12:51 PM
I have had it put back on the diagnostic machine and no codes were found
Lekko
07-12-2023, 12:51 PM #8
Views 649
06-01-2024, 08:26 AM
Last Post by bigdave1701
Views 114
08-12-2023, 01:42 PM
Last Post by yaser01
Views 378
09-10-2023, 03:21 PM
Views 423
04-10-2023, 12:38 PM
Last Post by CrocodileHunter
Replies 22
Views 1,429
27-07-2023, 11:45 AM
Replies 52
Views 3,065
14-07-2023, 09:41 PM
Last Post by Mr_Woods
Views 834
25-05-2023, 06:58 AM
Views 458
24-05-2023, 01:50 PM
Last Post by ViperTheLex
Views 695
20-05-2023, 07:02 AM
