JapCarForum General Discussions New Members is200 supercharged losing power
tastynoel
29-11-2021, 02:57 PM
Hi all I am new here I got my supercharge is200 2 weeks ago and it was running very good till it started losing power when I give take off hard and when I turn the car off and start it again it is fine till I do the same thing again any help will be much appreciated Thanks
tastynoel
29-11-2021, 02:57 PM #1
29-11-2021, 03:57 PM
Sounds like either the throttle cable is too tight or the black box is failing. Any fault codes showing or the Ecu light coming on?
29-11-2021, 03:57 PM #2
tastynoel
30-11-2021, 04:28 AM
No fault lights showing or ecu light coming on I will try the throttle cable thanks for the reply
tastynoel
30-11-2021, 04:28 AM #3
30-11-2021, 04:37 AM
Odd question, does the ecu light work? (Ie come on then off when you start the car)
As I would expect some fault code to come up
30-11-2021, 04:37 AM #4
tastynoel
30-11-2021, 04:49 AM
Ya that ecu light is working fine just looked at the throttle cable it is tight enough how lose should it be
tastynoel
30-11-2021, 04:49 AM #5
30-11-2021, 09:20 AM
The throttle cable to the super charger bypass should have a cm or so of slack at the charger bypass end
30-11-2021, 09:20 AM #6
tastynoel
30-11-2021, 09:25 AM
Ya that fixed the problem it is about half a cm slack now is that enough thanks a mill sparky mush appreciate
tastynoel
30-11-2021, 09:25 AM #7
30-11-2021, 12:36 PM
No problem, glad I could help
30-11-2021, 12:36 PM #8
kevinsgs300
03-12-2021, 10:45 AM
welcome to the club
kevinsgs300
03-12-2021, 10:45 AM #9
welcome to the club
Views 350
04-08-2023, 07:03 AM
Views 301
18-11-2021, 08:16 AM
Last Post by jeorje_2000
Replies 188
Views 4,387
28-07-2021, 11:46 AM
Views 365
21-07-2021, 11:49 PM
Views 230
16-05-2021, 08:58 PM
Last Post by 350zLad
Views 272
27-12-2020, 02:17 PM
Last Post by Jimbob-T-Lex
Views 321
13-12-2020, 01:12 AM
