JapCarForum Cars, Cars, Cars! General Car Maintenance ITB throttels on 1GFE
Danis200
16-02-2023, 10:46 PM
I've been searching if it's possible to get or put itb's on a
1gfe engine? Had somebody done it or try it before? I've seen itb kits on a 1jz-ge engine. To me it look the same,but can it be possible to put it on a 1gfe engine.
Danis200
16-02-2023, 10:46 PM #1
17-02-2023, 02:06 AM
Waste of money! Try another route.
17-02-2023, 02:06 AM #2
17-02-2023, 03:59 AM
You will need a custom set made and then an after market ECU to run the car. It will run well into the thousands of pounds just to gain yourself maybe 5 HP per cylinder if you are very lucky.
Would probably sound wicked though.
17-02-2023, 03:59 AM #3
Danis200
17-02-2023, 04:08 AM
I understand. It's possible than. 6 times 5hp,is 30hp moreSmile. But is more that i'll do to the engine. Like exhaust manifold,lightweight flywheel and clutch and 2,5 inch catback system. So i would be very happy to get close to 200hp. Don't forget the stand alone ecu. But do you know where i can get itb's,like the kit thet have for the 1jz or 2jz engines?
Danis200
17-02-2023, 04:08 AM #4
Wayne
17-02-2023, 05:16 AM
Seems a very expensive way to get around 200hp
Wayne
17-02-2023, 05:16 AM #5
17-02-2023, 09:28 AM
I don't know where you'll get them from, but I had a mate who was looking to fit the bmw m3 individual throttles to his supra. They could a good project? Maybe not full itb's but could be good
17-02-2023, 09:28 AM #6
17-02-2023, 01:31 PM
Jenvey would be my first port of call. I'd have thought m3 throttle bodies would be too big.
17-02-2023, 01:31 PM #7
Views 628
28-02-2021, 11:38 AM
Last Post by jeffrosie
