JapCarForum Cars, Cars, Cars! General Car Maintenance new 1GFE BEAMS idle problems, mid-range power lag and its noisy
hasibul.a.khan
18-11-2020, 11:43 AM
Hey Guys,
I'm new here. Been goin through some of your projects and they are inspirational to say the least.
Anyway I've got a 2004 Mark II Blit iR and the old engine died. So I got a replacement 1gfe in along wit a gearbox. I was careful with the inspection and did a compression check, changed the oil n sparks, checked the seals and ignition coils and everything is fine. First crank and the engine turned firing on all sixes.
Everything was fine untill the engine got hot. Idle went up to 2k and in gear it drops to 1200 at it sounds really rough. At first I thought it was a new engine thing so I went along with the break in process and the problem only got worse. cold starts still beautiful no complaints no problems but as soon as it heats up idle jumps to 2k and it gets very noisy but i can still live with all that but what i cant live with is the way i have to keep pushing the throttle to get it past 100. Once past that it sprints all the way to 180.
I've never seen such random behaviour but i've also never driven vvt-i's before. So i'm at a loss for solutions. Sumone suggested resetting the ecu might help. I need sum pro help here guys. Sad Any Suggestions???
hasibul.a.khan
18-11-2020, 11:43 AM #1
Hey Guys,
Views 966
17-02-2023, 01:31 PM
Views 908
07-05-2022, 11:06 AM
Last Post by piman2k
Replies 61
Views 2,151
25-11-2021, 11:04 AM
Last Post by john wan
Views 679
28-02-2021, 11:38 AM
Last Post by jeffrosie
Views 527
26-09-2020, 08:05 AM
Views 359
18-06-2020, 03:24 AM
Last Post by is300_dino
Views 1,627
21-04-2019, 01:15 AM
Views 1,276
23-12-2017, 10:20 PM
Replies 18
Views 1,260
15-09-2017, 05:49 AM
Views 569
30-08-2016, 04:12 AM
