JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Boosting
Boosting
Boosting
Mr_Woods
10-06-2023, 10:06 PM
Morning all, not sure if there's another thread on this but what would be better, turbocharging or supercharging my is200?
I love the whine of the supercharger and the fact that as its belt driven the boost is there when you need it but can you fit a dump valve to it?
On the other hand I love the whistling of a turbo, especially with dump valve attached and the fact there is a build up boost gets the adrenaline going.
As we all know the is200 is around 153hp so would like to see which mod also offers the best performance gain.
Thanks all :biggrin:
Mr_Woods
10-06-2023, 10:06 PM #1
10-06-2023, 10:16 PM
again its hard to say,
i run a DIY supercharger and for money value its better my kit cost around £700 with minimal work to the engine and ecu, plus any dramas i can just disconnect and still run the car NA, power wise with a charger you can get between 200-220bhp on the 130mm pulley so plenty of extra power for not to much £££.
with regards the BOV yes you can fit one to a charger however it needs to run along side a Bypass as the pressures from a charger wont work a BOv alone correctly, if its just a noise you want then a bypass will do that and i ran just a bypass for years and have just fitted a BOV to work along side
Edited 22-07-2016, 07:51 AM by Lexuspat.
10-06-2023, 10:16 PM #2
10-06-2023, 10:20 PM
with regards Turbo you have more scope for bigger power but if your gonna fit a turbo you need the money behind you to do it right, cheap copies of turbos arent very good and ECU for best mapping will be needed Jimbob built his turbo kit so maybe ask him with regards cost whats needed and things like that.
me personally a turbo needs to be done right as if that goes then the engine is dead until its repaired.
would i have liked a turbo of course but the money behind building a kit like that and the items that you need made it less viable then building a charger kit from scratch
10-06-2023, 10:20 PM #3
is200turbo
10-06-2023, 10:44 PM
I will second the turbo route is not cheap I think I'm £2000 into it and that's goin cheap on some things (second hand etc) the turbo was £1100 on its own but it's a brand name, the Ecu is next on my list to get.
is200turbo
10-06-2023, 10:44 PM #4
10-06-2023, 10:47 PM
yeah as above some things you just cant cheap out on, ive seen turbo builds done at around just about 2k but the turbo is cheap and cant see it lasting long and then thats without an ecu as well
10-06-2023, 10:47 PM #5
is200turbo
10-06-2023, 10:53 PM
That's without building the engine to run over 0.5 bar. If you can't find 1g-gte pistons and rods there is some forged out there but there £1800 a set
is200turbo
10-06-2023, 10:53 PM #6
Mr_Woods
10-06-2023, 11:52 PM
Wow, thanks mate I think I may be joining you in taking the supercharger rout, as you say it can just be disconnected and run as normal. plus its cheaper and you get power gain for less work.
thanks mate
Mr_Woods
10-06-2023, 11:52 PM #7
thanks mate
Wayne
11-06-2023, 02:33 AM
So far my build is around the £700 mark for the supercharger. By the time it's on the car it'll be around £900. The two most expensive bits were the charger and cradle. I wouldn't even entertain turboing mine. I'd rather just stick a new engine in.
Wayne
11-06-2023, 02:33 AM #8
11-06-2023, 03:22 AM
Worth noting that there are plenty of other sized pulleys available on the Facebook groups. Not sure what a 150mm will get you power wise but you can get one for less than 100 quid.
11-06-2023, 03:22 AM #9
Wayne
11-06-2023, 04:07 AM
I hear 150mm pulley gets you upto around 240. No idea what truth there is to that though.
Wayne
11-06-2023, 04:07 AM #10
Views 899
05-07-2017, 12:46 PM
