JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications boosting problems
boosting problems
boosting problems
micromarc
05-07-2017, 09:26 AM
fitted a boost gauge the other day, its showing that the car aint making any positive boostConfusedhock:
just changed the belt for a slightly smaller one in case that was slipping,no change
checked round all all the silicone hoses no obvious leaks.
the chargers definatley creating plenty pressure but dont know where its goin!!!!!!?
micromarc
05-07-2017, 09:26 AM #1
05-07-2017, 09:31 AM
Where did you tee into the silicone pipes to fit boost sensor mate?
Most people put it on the intake side, when fitting supercharger.
05-07-2017, 09:31 AM #2
05-07-2017, 09:38 AM
Rabsters next to me and said it should be taken from the vac hose on the throttle body. There is a picture in his gallery
05-07-2017, 09:38 AM #3
micromarc
05-07-2017, 10:31 AM
i t'd in to the vac line for the dump valve, which i t'd from the vac hose at the throttle body the one closest to the left
micromarc
05-07-2017, 10:31 AM #4
Here's where mine T's into mate..
[Image: boostgaugefittinglex2.jpg]
[Image: boostgaugefittinglex1.jpg]
Sounds like you've done the same as me mate, so not sure??
05-07-2017, 10:31 AM #5
micromarc
05-07-2017, 10:49 AM
yeah just been out and checked cant see anything differentSad i m hoping its in the gauge thats not working properly
micromarc
05-07-2017, 10:49 AM #6
05-07-2017, 10:58 AM
Can you get us any pics of yours mate?
05-07-2017, 10:58 AM #7
micromarc
05-07-2017, 11:02 AM
of where i ve t'd in or the whole set up?
micromarc
05-07-2017, 11:02 AM #8
05-07-2017, 11:31 AM
Silly question but dies the gauge read low enough?
05-07-2017, 11:31 AM #9
micromarc
05-07-2017, 11:38 AM
yeah the gauge is in psi and goes in incriments of 2 so i should be expecting to see it at the second ie 4psi
micromarc
05-07-2017, 11:38 AM #10
Views 1,021
21-06-2023, 04:26 AM
Views 757
25-11-2019, 12:18 PM
Last Post by argyle dan
Views 394
02-08-2019, 07:38 AM
Last Post by farnsworth67
Views 495
24-02-2019, 05:29 AM
Last Post by lookatmybiceps
Views 551
29-09-2017, 08:06 AM
