JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Imitation tial q 50mm blow off valve
phaebo
16-08-2023, 11:01 PM
Hi all
I am currently running supercharger setup with 163mm pulley but i need a bigger blow off valve.
Now i have a imitation hks blow off valve with 25mm fitting. It works great but i need one with bigger capacity.
Has anyone experience with the tial q imitation blow off valves?
Are they good?
Have never had any problems with my hks imitation and a real tial blow off cost more then 200 pound.
The imitation are around 40.
This is the one i was looking for
http://m.ebay.co.uk/itm/UNIVERSAL-50MM-B...nav=SEARCH
phaebo
16-08-2023, 11:01 PM #1
Hi all
Are they good?
18-08-2023, 10:27 AM
I have a turbosmart raceport, but some of the small turbosmart ones are excellent.
Personally having seen various cheap blow off valves open at part throttle and basically throwing power away id always recommend a proper one
18-08-2023, 10:27 AM #2
phaebo
27-08-2023, 03:56 AM
Thanks for the info.
Seems that these bigger bovs are pretty expensive.
I have ordered a cheaper one first. Gonna try and test it out. If it does not work good enough ill buy a genuin instead.
I see soon enough if it will leak. Or doesnt dump the air good enough
phaebo
27-08-2023, 03:56 AM #3
Replies 59
Views 2,359
03-04-2024, 01:04 PM
Last Post by Keeperlit19
Views 199
30-06-2021, 10:51 AM
Last Post by phaebo
