JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Vacuum bypass valve
Vacuum bypass valve
Vacuum bypass valve
Pages (6): 1 2 3 4 5 6 Next
marko45
29-06-2020, 05:46 AM
Hi, I have recently installed the TTE supercharger kit.
I have seen this vacuum bypass valve "upgrade" http://www.outlawjapclub.co.uk/forum/sho...pass+valve
Is it really interesting in terms of power or torque at low revs?
Does someone know where I can buy it?
marko45
29-06-2020, 05:46 AM #1
phaebo
03-07-2020, 11:30 PM
I also would like to know this.
I can imagine that this will give much more torque at part throttle, because now only have power when i floor the peddle. With this vacuum bypass allready got boost when you touch the gas.
phaebo
03-07-2020, 11:30 PM #2
196
04-03-2021, 06:00 AM
have you go pictures? i have just bought one and want to see how others have installed it.
lexusdaydreaming
04-03-2021, 06:00 AM #3
marko45
04-03-2021, 06:39 AM
I do not have pics because i do not have it. But where did you buy yours ? Got a web link ?
marko45
04-03-2021, 06:39 AM #4
196
04-03-2021, 06:44 AM
i bought mine from bmw i got the part number from phebo it was 65 pound new.
lexusdaydreaming
04-03-2021, 06:44 AM #5
196
04-03-2021, 06:55 AM
It is from a mini cooper s r53
part nr 11617568423 from bmw garage or mini garage.
lexusdaydreaming
04-03-2021, 06:55 AM #6
rob
04-03-2021, 02:01 PM
I looked at that one before its different with a longer arm to the original one. For some reason I remember it didnt work as well.
rob
04-03-2021, 02:01 PM #7
04-03-2021, 10:10 PM
From what ive heard the mini one works well and thats what im gonna start using on the kit im building
04-03-2021, 10:10 PM #8
phaebo
04-03-2021, 11:00 PM
The mini is one with vacuum controlled valve. It doesnt matter how long the arm is
phaebo
04-03-2021, 11:00 PM #9
marko45
04-03-2021, 11:51 PM
But with that mini bypass valve, the bolt mounting pattern is not the same as the TTE one. So how will you guys install it ?
marko45
04-03-2021, 11:51 PM #10
 5 Guest(s)
 5 Guest(s)
Views 554
27-08-2023, 03:56 AM
Last Post by phaebo
Views 467
06-04-2023, 02:00 AM
Views 917
28-09-2022, 06:39 AM
Views 200
30-06-2021, 10:51 AM
Last Post by phaebo
Views 255
20-03-2021, 10:31 PM
Views 663
14-02-2021, 09:05 PM
Views 778
27-01-2021, 12:25 AM
Last Post by reganlives
Views 217
07-03-2020, 12:49 PM
Views 629
16-03-2019, 08:58 AM
