JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Bypass cable set up
Bypass cable set up
Bypass cable set up
argyle dan
04-01-2020, 10:25 AM
Hi,
I've just replaced my bypass cable and I am looking for the correct setting for the cable. I've read previous threads on this subject but all the pictures have been removed so not much help really. I would just use my previous settings but they weren't any good really car would cut out on occasion when I would slam on the throttle,not good for the throttle motor really. I know every car is different but there must be a common setting I can start from.
Cheers Dan
argyle dan
04-01-2020, 10:25 AM #1
Hi,
Cheers Dan
04-01-2020, 10:35 AM
You want quitea bit of slack, then press the throttle down and leave it with a tiny bit of play.
04-01-2020, 10:35 AM #2
bravo565
25-05-2020, 08:06 PM
I'm in the same boat myself mate . I just installed a sc on my is and the bypass cable drive arm doesn't move until the very end of the throttle travel . Is this normal? Do I have to remove something from the throttle body where it's bolted so the arm moves instantly? Also should the bypass valve be fully closed when full throttle is achieved? Struggling to find info on the setup procedure.
bravo565
25-05-2020, 08:06 PM #3
25-05-2020, 11:29 PM
It should be all but closed yes. Should have a little movement at full throttle so there's not too much strain on the throttle body motor.
25-05-2020, 11:29 PM #4
bravo565
25-05-2020, 11:42 PM
Many thanks the arm bolted on the body itself doesn't seem to pivot until full throttle I bolted it on but didn't change anything at the body end do you think I need to remove something from the drive before I bolt it tight?
bravo565
25-05-2020, 11:42 PM #5
bravo565
26-05-2020, 12:12 AM
Don't worry excellent advice all sorted now . Cheers mate.
bravo565
26-05-2020, 12:12 AM #6
26-05-2020, 12:40 AM
Glad you sorted it mate!
26-05-2020, 12:40 AM #7
daveo
06-02-2021, 09:05 AM
im looking to buy one of these cables as mine is broke, can someone help please
daveo
06-02-2021, 09:05 AM #8
bravo565
06-02-2021, 09:19 AM
Hi there I had the same problem I bought a throttle cable from rcs cables on eBay a 2 meter is fine then you will need to take the outer spring ending from your original and fit it to the end of the new cable sheathing on the throttle end. Set up the bypass after that and cut the cable to length. Don't make it too tight or the elm light will come on
. Bit of messing around but it does work fine. To get the tension right put the ignition on with a prop in the accelerator as the body will not pull the cable through otherwise. It took me two cables to get right as when they are cut that's it and the resistance in the sheathing with a frayed cable is too much. Hope this helps
bravo565
06-02-2021, 09:19 AM #9
daveo
06-02-2021, 09:27 AM
tell me while i have you.... i have a few lexus breaking....i can surely use a cable from them ??? any pic of either end of your cable when setup?? would greatly appreciate it as im at a standstill!!Smile
daveo
06-02-2021, 09:27 AM #10
Replies 59
Views 2,358
03-04-2024, 01:04 PM
Last Post by Keeperlit19
Views 465
06-04-2023, 02:00 AM
Views 915
28-09-2022, 06:39 AM
Views 777
27-01-2021, 12:25 AM
Last Post by reganlives
Views 628
16-03-2019, 08:58 AM
Replies 25
Views 1,142
10-02-2019, 02:19 PM
Last Post by S
Views 546
16-07-2018, 12:42 PM
Last Post by spud1973
