JapCarForum Cars, Cars, Cars! General Car Maintenance Help Please, HID Problem
TommyH
13-10-2016, 10:27 AM
Hello folks, stopping outside my work tonight i turned off my lights, passenger side went out but drivers side kept flickering on and off. I turned the ignition off and the lights went off, turned enine on then lights on, same flickering from passenger side. I then turned off the engine and flashed the lights and they just flashed as normal. Anyone any ideas why they are flickering ?
Cheers, Tommy
TommyH
13-10-2016, 10:27 AM #1
Cheers, Tommy
aaronabbott
13-10-2016, 10:30 AM
dodgy fuse,poor conncetion?
aaronabbott
13-10-2016, 10:30 AM #2
13-10-2016, 10:32 AM
Failing ballast ? Try swapping the ballasts from side to side if you can, and see if the problem follows.
13-10-2016, 10:32 AM #3
TommyH
13-10-2016, 10:47 AM
I'll try swapping the ballasts over once the gale force winds and howling rain eases up a bit.
TommyH
13-10-2016, 10:47 AM #4
13-10-2016, 11:13 AM
could be a faulty relay.
13-10-2016, 11:13 AM #5
TommyH
13-10-2016, 12:15 PM
Just went out and checked connections and the light is working now, both balasts are making a little buzzing sound, is this normal ?
TommyH
13-10-2016, 12:15 PM #6
aaronabbott
13-10-2016, 12:18 PM
yeah mine do aswell
aaronabbott
13-10-2016, 12:18 PM #7
yeah mine do aswell
13-10-2016, 01:29 PM
your connections could be a bit corroded?
13-10-2016, 01:29 PM #8
Views 943
28-04-2018, 03:22 AM
Views 682
04-02-2017, 10:21 PM
Views 772
16-10-2016, 07:58 AM
