JapCarForum Cars, Cars, Cars! General Car Maintenance Battery Problem
Battery Problem
Battery Problem
dan1396
04-02-2018, 06:16 PM
Right i wonder if any one can help me out on this.
I have a 2001 toyota corolla E11.
I think the battery on the car is dead because nearly every morning it needs to be jump started. but sometimes after leaving it sitting for 2 days it starts fine or will some time start fine in the mornings, other times it will start fine in the mornings and ill do a lot of running about during the day and the battery would have gotten more than enough charge. but the ill park it up and let it sit for a few hours and the battery will be dead flat and need a jump start.
Is it a problem with the battery or something else?
Dan
dan1396
04-02-2018, 06:16 PM #1
Dan
04-02-2018, 06:19 PM
its your radio.
or it could be your glovebox...
04-02-2018, 06:19 PM #2
its your radio.
04-02-2018, 06:22 PM
boot light maybe it could be any one of the fillament lamps internally that is functioning when the car is off i had a similar problem in my vectra the boot switch had died and was allowing the light to be on all the time drained the battery
04-02-2018, 06:22 PM #3
04-02-2018, 06:25 PM
Ahhh yes, convert to led's dan
04-02-2018, 06:25 PM #4
04-02-2018, 06:51 PM
Even if something is on and draining the battery, it would have to be draining it quite a lot for it to be dead after a few hours. I suspect the battery is knackered (not holding a charge). The cold weather can accelerate this.
Do you have a multimeter or similar so you can test the voltage of the battery ? You might find somewhere that will test it for free for you (but then turn down their offer of a replacement battery and shop around for the best deal !).
04-02-2018, 06:51 PM #5
05-02-2018, 04:10 AM
Some battery leads have two nuts (on the positive) one that goes over the battery, the other you also have to make sure is tight.
Most people think that the one that locks onto the battery is the main nut to tighten but you need both done up tight to charge the battery.
I can not say that ive seen the toyota connection on you're car but it worth checking before spending your hard earned cash.
05-02-2018, 04:10 AM #6
Views 1,370
13-04-2023, 06:01 PM
Last Post by MichaelTTE
Views 1,441
10-12-2021, 07:03 PM
Last Post by jeffrosie
Views 1,810
12-06-2020, 07:26 AM
Views 1,989
28-04-2019, 09:10 AM
Views 1,640
16-10-2017, 01:47 PM
Views 1,428
13-10-2017, 07:18 PM
