JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission clutch slipping
clutch slipping
clutch slipping
aaronabbott
25-10-2016, 07:07 AM
i think my clutch has just started to start slipping,in a worst case scenario and the clutch is knackered will it be possible to just change it and the flywheel will be ok or do they both go at the same time
aaronabbott
25-10-2016, 07:07 AM #1
25-10-2016, 08:03 AM
mine went at the same time mate Sad defo get it checked sooner rather than later though as the longer you leave it the more chance the flywheel will go and I won't even tell you how much a OEM flywheel from lexus costs you may cry :p
25-10-2016, 08:03 AM #2
25-10-2016, 08:04 AM
yeah the flywheel should be ok, just need the garage to check its still flat when they remove the clutch.
25-10-2016, 08:04 AM #3
aaronabbott
25-10-2016, 08:06 AM
ok I'll get some prices first thing in the morning
aaronabbott
25-10-2016, 08:06 AM #4
25-10-2016, 08:40 AM
When my clutch went I only got the clutch changed .
We did nothing with the fly wheel.
I got my one for *****x ( a couple of years ago) but would go somewhere else for it matey.
25-10-2016, 08:40 AM #5
25-10-2016, 09:17 AM
Check it ASAP. If you have caught it relatively early then your flywheel should still be fine.
25-10-2016, 09:17 AM #6
25-10-2016, 10:23 AM
i let my clutch slip for a while because i was awaitinig delivery for a clutch and the person changing the clutch said it was better to get the flywheel skimmed so try and get it done asap mate.
25-10-2016, 10:23 AM #7
25-10-2016, 11:13 AM
You can't get the OEM flywheel skimmed because it's a dual-mass one, you can only do that with a solid flywheel (e.g. aftermarket lightweight flywheel).
25-10-2016, 11:13 AM #8
25-10-2016, 11:21 AM
steviewevie You can't get the OEM flywheel skimmed because it's a dual-mass one, you can only do that with a solid flywheel (e.g. aftermarket lightweight flywheel).
you can mate,
your only flatting the face off after all.
25-10-2016, 11:21 AM #9
you can mate,
25-10-2016, 11:22 AM
Sparkystav you can mate,
Really ? ok, thanks, that's odd, I can't remember where I was told that you couldn't :confused1:
25-10-2016, 11:22 AM #10
Views 248
30-08-2020, 12:09 AM
Replies 18
Views 900
20-08-2020, 08:52 AM
Views 404
08-04-2018, 08:49 AM
Last Post by spud1973
Replies 29
Views 1,792
10-09-2017, 07:50 AM
Views 718
10-05-2017, 05:11 PM
Last Post by Asi
Views 610
02-10-2016, 11:25 AM
Last Post by wahidhussain
Views 437
12-07-2016, 04:15 AM
Last Post by Asi
Views 919
26-05-2016, 01:55 AM
Last Post by edeath
