JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Clutch - IS200 vs Altezza
15-05-2016, 11:11 PM
I'm starting to look around at new clutches. Am I right in thinking that the IS200 and Altezza use the same clutch components, i.e. release bearing as well as clutch plate, cover etc ?
Over on Toyo DIY it shows part numbers the same for the clutch plate but slightly different numbers for the clutch cover and release bearing. However, Exedy's website shows exactly the same components for both IS200 and Altezza.
So any Altezza clutch should fit ok ?
15-05-2016, 11:11 PM #1
21-05-2016, 10:44 AM
*cough* Anyone ? Stav ?
21-05-2016, 10:44 AM #2
21-05-2016, 10:53 AM
Well mine is running a UK Spec 3SGTE clutch and a standard gearbox if that helps?
21-05-2016, 10:53 AM #3
21-05-2016, 11:03 AM
2tongues Well mine is running a UK Spec 3SGTE clutch and a standard gearbox if that helps?
When you say UK Spec 3SGTE clutch, I thought the 3SGTEs were imports and not UK spec. Is that an MR2 clutch ?
21-05-2016, 11:03 AM #4
21-05-2016, 11:30 AM
Indeed an Altezza one does fit, but i think you have to use the standard IS200 bearing/
Stav
21-05-2016, 11:30 AM #5
Stav
21-05-2016, 11:52 AM
Sparkystav Indeed an Altezza one does fit, but i think you have to use the standard IS200 bearing/
Thanks, so the Altezza clutch cover fits the IS200 as well as the clutch disc itself ?
21-05-2016, 11:52 AM #6
21-05-2016, 12:57 PM
ay it does
21-05-2016, 12:57 PM #7
ay it does
21-05-2016, 01:16 PM
why you not just get a lexus one?not that expensive.
21-05-2016, 01:16 PM #8
21-05-2016, 11:36 PM
Thanks guys. Good question Ormi. I might well just end up getting a Lexus OEM one, yes, that's one of the options. As you say they are not particularly expensive. Don't think I'll be getting a Lexus flywheel though ! :ohmy:
21-05-2016, 11:36 PM #9
24-05-2016, 02:46 PM
how much you been quoted for a flywheel??matey
24-05-2016, 02:46 PM #10
Views 245
09-01-2023, 02:08 PM
Last Post by Hoseer
Views 240
10-02-2022, 04:05 PM
Views 240
15-01-2022, 02:19 AM
Views 196
27-04-2021, 11:43 PM
Views 852
24-04-2021, 04:30 AM
Last Post by lexusdaydreaming
Views 209
30-08-2020, 12:09 AM
Replies 18
Views 703
20-08-2020, 08:52 AM
Views 177
15-01-2020, 09:55 AM
Last Post by Jon
