JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission IS200 1g-fe upgrade Rods and Pistons to 1g-GTE
warhead3005
30-03-2020, 03:47 AM
Hi guys,
Im new to this forum so i appologize in advance if this is in the wrong area or theres already a thread like this,
Im going to be getting a turbo kit for the is200 1g-fe and noticed alot of talk about the 1g-gte Rods and pistons being put in to allow more power,
Im just wondering if anyone here has done this actually change and if theres any issues with bore size from wear and tear. As in the pistons and rods not fitting due to the wear and tear being different to my engine.
If anyone could shed some light on this that would be awesome!
Also if the installation was hard or not?
warhead3005
30-03-2020, 03:47 AM #1
Hi guys,
30-03-2020, 04:01 AM
Welcome mate!
I'm pretty sure it's the rings that wear rather than the actual pistons themselves. You'd obviously need new rings and bearings when fitting the gte rods and pistons.
30-03-2020, 04:01 AM #2
Welcome mate!
warhead3005
30-03-2020, 04:03 AM
Which rings and bearing would i be needing? i take it id need the 1g-gte rings? who sells these new
warhead3005
30-03-2020, 04:03 AM #3
S
30-03-2020, 05:07 AM
warhead3005 Which rings and bearing would i be needing? i take it id need the 1g-gte rings? who sells these new
Toyota only for the rings IIRC
Not sure about bearings
S
30-03-2020, 05:07 AM #4
30-03-2020, 06:30 AM
Check jimbobs thread here:
http://www.outlawjapclub.co.uk/forum/sho...php?t=7612
30-03-2020, 06:30 AM #5
Views 311
09-01-2023, 02:08 PM
Last Post by Hoseer
Views 297
10-02-2022, 04:05 PM
Views 300
15-01-2022, 02:19 AM
Views 247
27-04-2021, 11:43 PM
Views 1,125
24-04-2021, 04:30 AM
Last Post by lexusdaydreaming
Views 227
15-01-2020, 09:55 AM
Last Post by Jon
Replies 18
Views 892
13-12-2019, 10:14 PM
Replies 27
Views 1,928
23-05-2019, 09:41 PM
Views 869
29-04-2019, 03:02 PM
