JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission IS200 Wont start/Bad misfire
Pages (3): 1 2 3 Next
jonesy200
18-01-2021, 09:15 AM
Hey all I'm new to the form. I bought an is200 with the head gone. it wouldn't start before i did the rebuild either same problem. it wants to and sometimes fires into life just. with my foot plouged to the floor if i take my foot off the gas it stalls. I have had the head totally rebuilt new everything spark plugs and second hand injectors. I pulled the fuel pump out and put a live feed on it it works but doesn't seem to suck or give any signs of forcing fuel etc and i cant hear it when ignition is switched on? could it be the pump given up?
jonesy200
18-01-2021, 09:15 AM #1
jonesy200
18-01-2021, 09:16 AM
Also it has no diag codes thrown up?
jonesy200
18-01-2021, 09:16 AM #2
18-01-2021, 09:25 AM
I'd check the relay, I think it's the circuit opening one that powers the fuel pump
18-01-2021, 09:25 AM #3
jonesy200
18-01-2021, 09:28 AM
how would i check/test a relay?
jonesy200
18-01-2021, 09:28 AM #4
18-01-2021, 09:43 AM
a simple way is to get someone turn the car on and have your fingers on the relay to see if it moves.
But to test it properly you need to take it out and check it works on 12v and the contacts have continuity.
18-01-2021, 09:43 AM #5
jonesy200
19-01-2021, 01:24 AM
Ok so iv ruled out the fuel pump for now as its getting fuel to the injectors. What i did was i unplugged 1 coil and cranked it and it was trying to start as usual with no change which leads me to think i got a few bad coils? as before I done the rebuild i read the codes and it came up with p0301 and p0305 but cleared them silly me. since clearing them the car hasnt run no did it previous to clearing the codes so hasnt given the ecu chance to refind the faults so have i got a case of a few bad coils??
jonesy200
19-01-2021, 01:24 AM #6
19-01-2021, 01:38 AM
Take each coil out and turn the car over, see if your getting a spark
19-01-2021, 01:38 AM #7
jonesy200
19-01-2021, 01:52 AM
they all getting a spark so im baffled lol.
jonesy200
19-01-2021, 01:52 AM #8
is200turbo
19-01-2021, 04:15 AM
It's not something silly like a bad lamba sensor or a cat breaking down.
is200turbo
19-01-2021, 04:15 AM #9
jonesy200
19-01-2021, 10:20 AM
Ok so after tons of research I've finaly found that my timing was out by 180 degrees as I lined up the bottom crank with the first mark on the pully not with the correct second mark. So its cams off tomorrow, set bottom end then refit the cams tdc and hopefully job done!
jonesy200
19-01-2021, 10:20 AM #10
Views 310
09-01-2023, 02:08 PM
Last Post by Hoseer
Views 296
10-02-2022, 04:05 PM
Views 299
15-01-2022, 02:19 AM
Views 601
18-10-2021, 01:45 AM
Views 246
27-04-2021, 11:43 PM
Views 172
12-05-2020, 03:26 AM
Last Post by Ji123
Views 227
15-01-2020, 09:55 AM
Last Post by Jon
Replies 18
Views 892
13-12-2019, 10:14 PM
