JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission 10K service
10K service
10K service
James S
16-11-2016, 09:01 AM
My car has just about done 10k since last service. Now I know its due a cam-belt change asap. But need to give it an oil change, and going to buy a K+N filter too. But do I need to change spark plugs? They were done with last service.
How difficult is an oil change??
James S
16-11-2016, 09:01 AM #1
James S
16-11-2016, 09:26 AM
Bosch spark plugs. Will try do oil change tomorrow, what sort of oil is best? And how much will I need? :tongue_smilie:
James S
16-11-2016, 09:26 AM #2
16-11-2016, 09:28 AM
James this is what your car needs,
5w-30 synthetic
16-11-2016, 09:28 AM #3
5w-30 synthetic
16-11-2016, 10:02 AM
i done a walk through on servicing your car, you should have a look before diving in!
16-11-2016, 10:02 AM #4
James S
16-11-2016, 10:18 AM
Wicked, have you got a linky???
James S
16-11-2016, 10:18 AM #5
16-11-2016, 10:24 AM
click on toyota/lexus then go down to the workshop its in their matey i done the oil and filter change,gear oil change and diff oil change...
16-11-2016, 10:24 AM #6
James S
16-11-2016, 10:56 AM
Wicked, thanks mate
James S
16-11-2016, 10:56 AM #7
Wicked, thanks mate
16-11-2016, 10:57 AM
let me know how you get on.........hope the walk through helps.....
16-11-2016, 10:57 AM #8
James S
16-11-2016, 11:02 AM
Yeah thats spot on, got a couple of questions though, if you don't mind.
Is it worth using engine flush to clean the engine before new oil goes in? And would it matter if I did the change on a hill??? Can use a drive if needed, but it won't be outside my house (so won't have all my tools handy)
James S
16-11-2016, 11:02 AM #9
16-11-2016, 11:10 AM
nope i would never use engine flush,the lexus engine runs really clean i would only recomend this if the oil in your car was like tar!!to be honest you'd be better on a level surface but you could do the oil and filter change on the hill and then drive to a level surface and check.........................
i would do it on the drive though as for tools all you need is a jack,14mm spanner and a oil filter removal tool.......should take you no longer than 15mins but remember to run the car for approx 10mins to warm up the oil,it comes out faster....
16-11-2016, 11:10 AM #10
Replies 31
Views 1,561
17-02-2017, 01:46 AM
Last Post by edeath
