Full service
Full service
OK its time to give the car its 90,000 service ok its not done that many but that is the service that is due
What do you think i should change, car is going on the swiss alps trip so needs to be running well moke:
Going to change oil and belt on the charger
Spark Plugs maybe
Oil (need to fit sandwich plate and sensor's)
is it worth changing my discs and pads i have new front discs and pads early last year but thinking maybe some mintex front and rear or similar
Advice guys :thumbup:
gearbox oil, diff oil could also be an option,
a good clean of the air filter, and an ecu reset cant hurt
What kind of oil you going to use Rabster ??
Cant see the point in changing disc and pads that are relatively new , but thats beside the point when doing upgrades LOL
i was going to ask opie oils for the recommendation on the oils as i haven't got a clue lol
i have the same oil we used in woz's charger when i serviced that
cam belt was done at 60k ish near the 70 i think will check
might do all ancillary belts whilst im at it
Aircon done last summer then didnt use the car lol
Rabster i was going to ask opie oils for the recommendation on the oils as i haven't got a clue lol
My last service I changed Engine Oil and filter. Gearbox Oil and Diff Oil and Supercharger Oil.
I used:
Silkolene Pro S 5W-30 and UFI 23.253.00 Oil filter (5L Bought)
Silkolene Silktrans (Gearbox. 2l Bought)
Silkolene BOA 90LS High performance Gear & LSD Oil (Diff and SC. 2l Bought)
About £99 all in from Opie. (Inc discount and P&P) and the amounts needed are available on the bahamut pdf.
I also cleaned the K&N and changed sparks to IK22s.
The car runs better than it ever has; to the point where it felt so much different to drive - so much smoother. I have a very similar setup to yourself I hope that helps.
Also just check the brakes and replace if they need it. No point swapping to Mintex for the hell of it as it is no better than OEM IMO (just cheaper )
Gimme a shout if you want a hand one weekend - it's easier with 2 people. Ideally you want a lift: I used a place in park royal where you can rent a lift for £20/hr. Called Pit Start I think.
