JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza JDM headlights
JDM headlights
JDM headlights
03-12-2016, 07:40 PM
are these the same as the satin ones?
http://cgi.ebay.co.uk/LEXUS-IS-200-300-S...2eaa6126bf
03-12-2016, 07:40 PM #1
Ally
03-12-2016, 10:30 PM
No, the satin ones look dark, but when the sun hits them they look a goldish colour. The ones in the link are the ones i have. Proper matt black. Will look great on your black car.
Have you checked the postage...£92:ohmy: I got mine from http://www.japanparts.com. I think they were about £280 and that was with the postage included.
Edited 15-01-2010, 09:03 AM by Ally.
JDM black headlights, rear fog light conversion, JDM size number plates, JDM rear number plate garnish, JDM dash tray, wind deflectors, TRD body kit, white TRD gearknob, TTE lowering springs, TTE ARB's, K&N air filter, stainless steel A/C rings, stainless clock cover, radiator cooling panel, LED side light bulbs, blue reversing bulbs, fan washer jets, clear side repeaters, PIAA silicone wipers, Alpine IDA-X200 headunit, 17 x 8 et40 OZ Ultraleggera with 225/45/17 Toyo Proxes T-1R
Ally
03-12-2016, 10:30 PM #2
04-12-2016, 03:06 AM
As above the satin ones are different, these ones also have a blue tint to them (as in the second pic) which the satin ones don't have. They also don't have the headlamp levelling motors but I believe you can swap in the ones from your headlights.
04-12-2016, 03:06 AM #3
04-12-2016, 04:43 AM
their basically from the Altezza's which afaik they don't have electronic beam adjustment, so you need to mount the backing off the ukspec headlights onto the Altezza's if you want to use the electronic adjustment.
04-12-2016, 04:43 AM #4
reganlives
04-12-2016, 05:04 AM
After all the mess up with the garage that I used to fix my car and when they damaged one of the headlights, the replacement headlight I got aint got a motor in it, can the motor from the damaged one be removed or does the whole light need to be taken apart and the backs swapped over?
reganlives
04-12-2016, 05:04 AM #5
04-12-2016, 05:11 AM
think the headlight needs properly splitting mate, yeah I know when mine got broken a garage couldn't find mine and refused to split them so I had to get the satin ones put in instead.
04-12-2016, 05:11 AM #6
04-12-2016, 10:39 AM
right i see. is the motor leveling motor really important? is it needed for mot?
thanks
04-12-2016, 10:39 AM #7
thanks
russelllinn
04-12-2016, 10:41 AM
Don't think it will be needed for MOT just need to make sure the beams are the right height which is what it basically does just electronically.
russelllinn
04-12-2016, 10:41 AM #8
04-12-2016, 10:48 AM
right i see. im thinking either these or satin ones. satin ones will have the motors on them and these dont.....but £400 is alot for jdm headlights
04-12-2016, 10:48 AM #9
russelllinn
04-12-2016, 11:02 AM
Asi right i see. im thinking either these or satin ones. satin ones will have the motors on them and these dont.....but £400 is alot for jdm headlights
It is quite a lot of money for sure how much are the satin ones? Could you look at some breakers and then paint the inners to save some cash?
russelllinn
04-12-2016, 11:02 AM #10
Views 496
07-08-2020, 12:31 PM
Last Post by wullie_trd
Views 268
06-05-2020, 12:49 PM
Last Post by Colin G
Views 890
18-06-2018, 11:05 AM
Views 1,283
30-11-2017, 03:49 AM
