JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza HEADLights not switching off
m4ddy
16-06-2019, 03:44 PM
HI all.
was after some help.
Ive had my car about 7 years and i've developed a problem that i first had when i got the car. Lexus replaced a junction box and a ecu to do with the alarm but i cant remember what exactly. im thinking its the same thing this time.
When you switch the ignition off the headlights and the rear lights stay on and wont turn off, even if the switch on the control arm is set to off.
With the ignition on and the car started on the lights still stay on and wont switch off. So i keep having to take the fuses out from the fusebox in the drivers side kickpanel. So that it doesnt draiin the battery when left parked up. Ive disconnected the control arm connector on the steering whheel and still the same so it cant be the control arm switch.
Ive read that you may have problems if u've had the windscreen replaced i.e that you could get water into the drivers sode kickpanel. but ive taken the driverside kick panel fuse box out and check all the connectors and there doesnt seem to be any water there.
I have read somewhere that the theft deterrant ecu would need replacing, but im just abit confused as to what or where that is.
Can someone tell me where that is and where i could possibly locate one?
Is this the same thing?
http://www.ebay.co.uk/itm/Lexus-IS200SE-...0313230131
[IMG]C:\Users\Maddy\Pictures\car phoos\fuse.jpg[/IMG]
the above is my drivers side kickpanel fuse box out.
Thanks
m4ddy
16-06-2019, 03:44 PM #1
HI all.
Thanks
m4ddy
16-06-2019, 03:46 PM
oops forgot to say what car ive got lol
Lexus is200 sport, 2001.
NO modifications, all standard.
exept fog to brake conversion. And the pulsing brake lights.
m4ddy
16-06-2019, 03:46 PM #2
m4ddy
16-06-2019, 03:51 PM
i took a few photos whilst i had the fusebox out but i dont know how to attach them to my post :-(
m4ddy
16-06-2019, 03:51 PM #3
m4ddy
16-06-2019, 04:02 PM
ive uploaded some images onto net, here is the link
http://s1122.photobucket.com/albums/l533/scoobydoo999/
m4ddy
16-06-2019, 04:02 PM #4
16-06-2019, 04:04 PM
Sorry I can't help on the light problem. It seems a coincidence that your only mods are light related and you have a light related problem. But I'm quite sure it is just that, a coincidence, as I do not think they are related!!!
But look here >>> http://www.outlawjapclub.co.uk/forum/sho....php?t=200 for help on posting photos mate. You need to link to them with [IMG] tags as you have, but you need the address of the image online (need to upload to photobucket or similar) and not on your computer as you have done. But you are nearly there!
EDIT: You are very close! Just copy and paste the IMG code from photobucket (hold mouse over thumbnail for this option.)
Here is one:
[Image: fuse.jpg]
Edited 28-07-2011, 07:50 PM by Stoney.
16-06-2019, 04:04 PM #5
Here is one:
[Image: fuse.jpg]
m4ddy
16-06-2019, 04:06 PM
cheers stoney.
ive had the light mods about 4 years and never a problem.
ive even taken out the led bulbs and replaced them with standard ones and still same , im quite sure its got nothing to do with the mods lol.
m4ddy
16-06-2019, 04:06 PM #6
cheers stoney.
m4ddy
16-06-2019, 04:10 PM
cheers mate , so here are my images.
[Image: 2011-07-24164034.jpg]
[Image: 2011-07-24163257.jpg]
[Image: 2011-07-24163233.jpg]
[Image: 2011-07-24163202.jpg]
[Image: 2011-07-24163127.jpg]
[Image: 2011-07-24160439.jpg]
[Image: 2011-07-24160410.jpg]
[Image: 2011-07-24160356.jpg]
m4ddy
16-06-2019, 04:10 PM #7
aaronabbott
16-06-2019, 04:56 PM
Check all connections on both fuse boxes,when I had the same problem with mine 1 connector was so knackered on the drivers side that I had to wire in another connector and 3 pins on the passenger side were almost gone the same way.
The theft deterant unit is (in the first pic) Literally just behind the ignition barrel,you will see 2 boxes it's the 1 on the left hand side of the 2
aaronabbott
16-06-2019, 04:56 PM #8
aaronabbott
16-06-2019, 04:58 PM
Oh and best way to turn the lights off while your checking these connections it the take the relay out of the engine fuse box instead of having to keep taking fuses out Of the kickpannel
aaronabbott
16-06-2019, 04:58 PM #9
16-06-2019, 05:32 PM
as above ever had a windscreen replacement ?
there is no obvious signs from the fuse box its got water damage...
do you know which lights are staying on ?
16-06-2019, 05:32 PM #10
Views 960
07-08-2021, 06:20 PM
Last Post by wullie_trd
Views 525
06-05-2021, 06:38 PM
Last Post by Colin G
Views 2,203
30-11-2018, 09:38 AM
Views 1,358
04-12-2017, 10:55 PM
Last Post by Asi
