JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Backing plate
Backing plate
Backing plate
TommyH
08-03-2017, 10:40 PM
Would it cause any problems if i removed the backing plate from the brake disc's ? No matter how much i bend it back it still makes this rubbing/droning noise :confused1:
TommyH
08-03-2017, 10:40 PM #1
08-03-2017, 11:51 PM
It's just there to contain the dust. I'm not quite clear if it's to stop the brake dust getting into somewhere specific (like the wheel hub), or just a general thing to keep things a bit cleaner.
08-03-2017, 11:51 PM #2
TommyH
09-03-2017, 12:49 AM
Thanks Stevie.
TommyH
09-03-2017, 12:49 AM #3
Thanks Stevie.
Phil01
09-03-2017, 05:35 AM
The back plate is also there to channel cooling air to the rear face of the brake disc, to stop water getting on to the disc as well,
I would reshape it and leave it in place.
Phil01
09-03-2017, 05:35 AM #4
Jambo
09-03-2017, 06:46 AM
It might be the break pads? Dean had a similar problem with his, but it was because his brake disk was slightly warn, leaving a lip on the edge of the disk. This then cought on the brake disks.... its common i though? (As it made the same noise without changing the pads)
Latest Meets
Ace Cafe 16/10/10,
Jambo
09-03-2017, 06:46 AM #5
Latest Meets
Ace Cafe 16/10/10,
Views 274
28-09-2020, 08:58 AM
Last Post by Kevpr
Views 224
31-05-2020, 12:37 AM
Last Post by reganlives
Views 736
21-08-2018, 11:17 AM
Last Post by northernmonkey
Replies 24
Views 1,407
07-07-2018, 08:04 AM
Last Post by jomo
Views 504
18-03-2018, 07:56 AM
Last Post by danielson
Views 1,228
25-01-2018, 03:28 PM
Last Post by is300_dino
Replies 44
Views 1,668
24-09-2017, 01:46 PM
Views 550
18-09-2016, 10:33 AM
